Home » Eclipse Projects » Hudson » Change Font Color (3.0.0)?
Change Font Color (3.0.0)? [message #998413] Wed, 09 January 2013 18:40 Go to next message
Shelli Orton is currently offline Shelli Orton
Member
We've just upgraded to 3.0.0 and noticed that when using the copy option to create a new project that the font color of the highlighted project in the list of projects to copy is white. Against the very pale purple (almost white) backround of the list, this renders it unreadable. Is there a quick CSS change or something else that we can make to fix this?
Thanks!
Re: Change Font Color (3.0.0)? [message #998440 is a reply to message #998413] Wed, 09 January 2013 20:32 Go to previous messageGo to next message
Winston Prakash is currently offline Winston Prakash
Hi, If you have installed the war in some container like tomcat, then it is expanded in to directory. There is a file called css/style.cc (in the css folder).
You have to modify the selector
.comboBoxSelectedItem {
background-color: #FF2222;
color: highlighttext;
Winston Prakash
Eclipse Hudson team
Re: Change Font Color (3.0.0)? [message #998802 is a reply to message #998440] Thu, 10 January 2013 13:09 Go to previous messageGo to next message
Member
Thanks!
I was able to set it to something readable.
Is this something that I should create a bug for? If yes, where would I do that?
[Updated on: Thu, 10 January 2013 13:09]
Report message to a moderator
Re: Change Font Color (3.0.0)? [message #999128 is a reply to message #998802] Fri, 11 January 2013 06:57 Go to previous messageGo to next message
Duncan Mills is currently offline Duncan Mills
Shelli,
Thanks for this. I've logged 397964 to track this
Duncan Mills
Eclipse Hudson team
Re: Change Font Color (3.0.0)? [message #999275 is a reply to message #999128] Fri, 11 January 2013 12:53 Go to previous message
Bug is fixed and should be available in 3.0.1
Duncan Mills
Eclipse Hudson team
Previous Topic:Plenty of errors after migrating from 2.1.2 to 3.0.0
Next Topic:Maven Release Builds Failing After Upgrade to 3.0
Current Time: Thu May 23 22:46:50 EDT 2013
Powered by FUDForum. Page generated in 0.04491 seconds
