Home » Language IDEs » Java Development Tools (JDT) » Eclipse PDE compatibility layer 3.3 to 4.2 migration
Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #989487] Thu, 06 December 2012 08:10 Go to next message
Brendan Healey is currently offline Brendan Healey
I'm trying to find some step-by-step/beginners guides to migrating features/plugins from Eclipse 3.3 to 4.2 Juno with the compatibility layer. I found some notes from Lars Vogel (unable to link - stupid error message) but right from the start I get stuck because I have no product configuration file (.product) and when it starts suggesting installing new plugins I've no idea where to get them from (i.e. org.eclipse.equinox.ds).
We're all stuck on 3.3 until I can get this package migrated, so any help much appreciated. If 3.3 to 4.2 is too much of a leap then any help for 3.7 to 4.2 and/or 3.3 to 3.7 would be extremely helpful.
Regards.
Brendan.
link error was: You can only use links to eclipse.org sites while you have fewer than 5 messages.
[Updated on: Wed, 09 January 2013 09:27]
Report message to a moderator
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #990237 is a reply to message #989487] Tue, 11 December 2012 09:23 Go to previous messageGo to next message
Thomas   is currently offline Thomas
Well, I hoped someone else with more knowledge would reply to this, because I really don't think I have enough knowledge to help much...
One question: have you tried using the old plugins on the new Eclipse directly? i.e. just drop all of the plugins in the dropins folder of your installation? I don't expect that to work really, but it is worth a try.
If you develop plugins in the "Eclipse for RCP and RAP Developers" from http://eclipse.org/downloads/ then you will automatically be developing plugins using the compatibility layer. In order to develop plugins for Eclipse 4.x natively you have to install the e4 development tools as described in http://www.vogella.com/articles/EclipseRCP/article.html which is recommended against in said article due to the fact that the APIs are still provisional.
This will be an exceedingly manual process, but I would recommend using http://java.decompiler.free.fr/?q=jdgui to get the source out of the plugins that you want to migrate and then importing them into projects in Eclipse and seeing what doesn't compile. Assuming that Eclipse has been good at maintaining backwards compatibility, there shouldn't be too many changes that you need to make.
I only have very minor Eclipse plugin development experience so I can't really help you on specifics.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #990260 is a reply to message #989487] Tue, 11 December 2012 11:08 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
> layer.
Assuming you only used official APIs, most of your stuff should just
work. The first thing to do is to go through each of the migration
guides that are provided with each release (Help > Help Contents > *
Plug-in Developer Guide.
Dani
> Regards.
> Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #998181 is a reply to message #990237] Wed, 09 January 2013 09:10 Go to previous messageGo to next message
Thomas & Dani, thanks for your replies. Apologies for my sporadic posting on here, I had some time off over the festive period.
I tried simply copying over the plugins and features from the old installation into Juno, and then when I start eclipse I get the following stack trace in the workspace/.../.log file:
!SESSION 2013-01-09 14:02:16.134 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
Framework arguments: -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.java.product
!ENTRY org.eclipse.jface 4 0 2013-01-09 14:02:20.400
!MESSAGE Undefined context while filtering dialog/window contexts
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet4
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.jface.bindings.BindingManager.createFilteredContextTreeFor(BindingManager.java:825)
at org.eclipse.jface.bindings.BindingManager.recomputeBindings(BindingManager.java:1721)
at org.eclipse.jface.bindings.BindingManager.contextManagerChanged(BindingManager.java:689)
at org.eclipse.core.commands.contexts.ContextManager.fireContextManagerChanged(ContextManager.java:165)
at org.eclipse.core.commands.contexts.ContextManager.setActiveContextIds(ContextManager.java:295)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:237)
I get the same exception for J2eeMainActionSet3, J2eeMainActionSet2 & J2eeMainActionSet, one after the other starting with J2eeMainActionSet4, then the messages:
!ENTRY org.eclipse.ui 4 4 2013-01-09 14:02:20.513
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet2
!ENTRY org.eclipse.ui 4 4 2013-01-09 14:02:20.514
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet3
!MESSAGE Unable to find Action Set: org.eclipse.jst.j2ee.J2eeMainActionSet4
I think the decompiler idea is a good one, but I think I need to address the above issues first.
Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #998259 is a reply to message #998181] Wed, 09 January 2013 12:14 Go to previous messageGo to next message
This is not supported and is expected to cause trouble (as you can see).
You have to download the build you need and install it into an empty folder.
Dani
> java.vendor=Oracle Corporation
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #998856 is a reply to message #998259] Thu, 10 January 2013 15:47 Go to previous messageGo to next message
Hi Dani, thanks for your reply. Forgive my ignorance, please can you supply some additional details. When you say it is not supported, what exactly isn't supported. And what build do you refer to?
Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #999051 is a reply to message #998856] Fri, 11 January 2013 03:24 Go to previous messageGo to next message
Copying an install over into a directory that already has another
Eclipse install in it.
As said: the one you need ;-). I don't know what kind of development you
plan to do. You might want to start with the Classic (a.k.a. Eclipse
SDK) download. Here's the latest candidate towards 4.2.2:
http://download.eclipse.org/eclipse/downloads/drops4/M20130109-1200/ .
Dani
> Brendan.
Re: Eclipse PDE compatibility layer 3.3 to 4.2 migration [message #1004996 is a reply to message #999051] Thu, 24 January 2013 04:32 Go to previous message
Hi, I wanted to clarify that I only copied files from the plugins and features directory
that were bundled with the package I'm trying to "port" over to Juno, I did not overwrite
any of the eclipse or other files.
I tried again with a freshly downloaded Eclipse Classic and this is what I'm seeing in the
log file...
This is looking to me like I probably need to decompile the code and rebuild in the Juno
PDK environment, does this seem reasonable or could I be missing something?
Thanks.
!SESSION 2013-01-24 09:26:24.713 -----------------------------------------------
!ENTRY org.eclipse.core.resources 2 10035 2013-01-24 09:26:25.868
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.324
!STACK 0
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:105)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.ui.bindings.internal.BindingServiceCreationFunction.compute(BindingServiceCreationFunction.java:32)
at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:60)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:229)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:238)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:200)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:68)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:107)
at org.eclipse.e4.core.internal.contexts.EclipseContext.runAndTrack(EclipseContext.java:299)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.get(ContextObjectSupplier.java:167)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveArgs(InjectorImpl.java:428)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:100)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processHandledItem(ToolBarManagerRenderer.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.modelProcessSwitch(ToolBarManagerRenderer.java:586)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer.processContents(ToolBarManagerRenderer.java:473)
at org.eclipse.e4.ui.workbench.renderers.swt.ToolBarManagerRenderer$5.handleEvent(ToolBarManagerRenderer.java:221)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUnique(NotifyingListImpl.java:294)
at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:301)
at org.eclipse.ui.internal.CoolBarToTrimManager.fill(CoolBarToTrimManager.java:728)
at org.eclipse.ui.internal.CoolBarToTrimManager.update(CoolBarToTrimManager.java:663)
at org.eclipse.ui.internal.WorkbenchWindow.updateActionBars(WorkbenchWindow.java:1807)
at org.eclipse.ui.internal.WorkbenchWindow.largeUpdateEnd(WorkbenchWindow.java:1860)
at org.eclipse.ui.internal.Workbench.largeUpdateEnd(Workbench.java:3105)
at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindow.java:2072)
at org.eclipse.ui.internal.WorkbenchWindow.setup(WorkbenchWindow.java:533)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:859)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:81)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.inject(ContextInjectionFactory.java:72)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1252)
at org.eclipse.ui.internal.Workbench.openWorkbenchWindow(Workbench.java:2324)
at org.eclipse.ui.internal.Workbench.getWorkbenchPage(Workbench.java:1737)
at org.eclipse.ui.internal.Workbench.setReference(Workbench.java:1756)
at org.eclipse.ui.internal.Workbench.access$22(Workbench.java:1753)
at org.eclipse.ui.internal.Workbench$33.handleEvent(Workbench.java:1693)
at org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl.setContext(PartImpl.java:399)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:609)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:518)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:503)
at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:74)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:98)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:646)
at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:59)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:642)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:59)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:639)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:968)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.327
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet3
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.328
!STACK 0
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.jst.j2ee.J2eeMainActionSet2
!ENTRY org.eclipse.jface 4 0 2013-01-24 09:26:28.329
!STACK 0
Previous Topic:Bookmarks Menu and IDE Ctrl-Click Suggestion
Next Topic:Problem with bundle org.eclipse.swt.win32.win32.x86_64 in config.ini
Current Time: Wed May 22 19:02:01 EDT 2013
Powered by FUDForum. Page generated in 0.01994 seconds
