| Incomplete product installation [message #998967] |
Thu, 10 January 2013 22:49  |
Thorsten Willard Messages: 7 Registered: January 2013 |
Junior Member |
I've just installed Eclipse Juno (4.2.1) and other programs work fine. When I create a designer Class the code is generated but when I try to go to designer I get:
Quote:Incomplete product installation
Incomplete product installation or upgrade detected. Please install or update the entire product. If the problem persists, un-install and re-install the entire product. Also ensure that the Eclipse JDT and PDE are fully installed as required by the system requirements
I did the following:
1. File->New->Java Project
2. Project name: MyProj (JavaSE-1.7)
3. Finish
4. Expand MyProj in Package Explorer
5. Right-Click on "src"
6. New->Other
7. Expand "WindowBuilder" folder
8. Expand "Swing" folder
9. Select "Application Window"
10. Next
11. Name: MyProj
12. Finish
13. Click "Designer" tab
I installed WindowDesigner from Help->Install new software
I selected all options when installing then did a "Check for Updates".
Help->About Eclipse->Installation Details->Installed Software Shows I have:
Swing Designer
WindowBuilder Core
WindowBuilder Core UI
WindowBuilder GroupLayout Support
Please Help, This is for a class I'm taking and really need to get this working.
FUDForum. Page generated in 0.01631 seconds
