Home » Modeling » EMF » [GWT] org.eclipse.emf.common.util.InvocationTargetException
[GWT] org.eclipse.emf.common.util.InvocationTargetException [message #998756] Thu, 10 January 2013 11:20 Go to next message
Dirk Hoffmann is currently offline Dirk Hoffmann
after generating the model from an ecore file for the GWT platform I get
the following error:
The type org.eclipse.emf.common.util.InvocationTargetException cannot be
resolved. It is indirectly referenced from required .class files
where is this class supposed to be taken from? I would expect that in
one of the org.eclipse.emf.gwt plugins but could not find it.
Thanks and regards,
Dirk
Re: [GWT] org.eclipse.emf.common.util.InvocationTargetException [message #998776 is a reply to message #998756] Thu, 10 January 2013 12:18 Go to previous message
Ed Merks is currently offline Ed Merks
Yes, if you set up a proper target platform with the EMF GWT runtime, it
will be found there.
On 10/01/2013 5:20 PM, Dirk Hoffmann wrote:
> get the following error:
> be resolved. It is indirectly referenced from required .class files
> Thanks and regards,
> Dirk
Previous Topic:[CDO] How to "flush" CDO Package registry ?
Next Topic:Weird call sequence on EStore with containment reference
Current Time: Wed May 22 17:39:29 EDT 2013
Powered by FUDForum. Page generated in 0.01453 seconds
