| Weird call sequence on EStore with containment reference [message #998725] |
Thu, 10 January 2013 10:06  |
Andreas Voss Messages: 1 Registered: July 2009 |
Junior Member |
I'm implementing an EStore to encapsulate our legacy database.
In my test scenario I have the classes "Customer" and "Account" and a 0..* containment reference "accounts", so a customer may own many accounts. When I call
customer1.getAccounts().add(account1);
EMF first performs some checks and then calls
1. myStore.add(customer1, reference, index, account1);
which is fine. myStore persists account1 and remembers its new container, customer1. Then EMF asks myStore for the container of account1:
2. myStore.getContainer(account1)
and myStore returns "customer1" which was just passed to myStore.add(). Then EMF decides to remove account1 from its container and calls:
3. myStore.remove(customer1, reference, index)
It looks like DelegatingNotifyingListImpl.addUnique() first calls addUnique() and then inverseAdd() which in turn calls eBasicRemoveFromContainer().
I would understand if EMF did something like:
oldContainer = store.getContainer(object);
if (oldContainer != null)
removeFromContainer(oldContainer, object);
store.add(newContainer, object);
but it looks like:
Any ideas what went wrong?
Thanks in advance,
Andreas
| Re: Weird call sequence on EStore with containment reference [message #998786 is a reply to message #998725] |
Thu, 10 January 2013 12:43  |
Ed Merks Messages: 24549 Registered: July 2009 |
Andreas,
Comments below.
> account1:
Do you have
org.eclipse.emf.ecore.InternalEObject.EStore.getContainingFeature(InternalEObject)
properly implemented?
> but it looks like:
Where does it look like this?
It's more like you add an x to a y, and then it tells the x (the other
end of the bidirectional reference) that it it should add y, and then x
knows (in this case) that it's a container reference, which is mutually
exclusive with any other containment reference, so it knows to remove x
from its current container before adding (setting actually) y...
I know Eike said this was really hard to implement this in CDO...
Probably it will be helpful to trace the same logic in a non-store
model. Perhaps it will be helpful to look at the CDO implementation...
> Thanks in advance,
> Andreas
FUDForum. Page generated in 0.02050 seconds
