Home » Eclipse Projects » Eclipse 4 » Dynamic menuitems in partmenu does not show up
Dynamic menuitems in partmenu does not show up [message #998686] Thu, 10 January 2013 09:02
Alexander Lampret is currently offline Alexander Lampret
Hello everyone!
I try to add DirectMenuItems with radio type to a menu inside a part. The label and number of items are determined from a hashmap. The number and names of keys are represented by the menuitems. But the menuitems only show up at first try.
After the second "calculation" of menuitems, only the radio buttons are shown. The number of items is wrong too.
MInputPart input = (MInputPart) modelService.find(ImageEditor.EDITOR_TEMPLATE_ID, application);
		MMenu menu = (MMenu) modelService.find(MENU_ID, input.getMenus().get(0));
		menu.getChildren().clear();
		ImagePlaneData data = getScan().getParallelData();
		MDirectMenuItem newElement;
		if (data.scanImageList.keySet().size() > 1) {
			for (String key : data.scanImageList.keySet()) {
				newElement = MMenuFactory.INSTANCE.createDirectMenuItem();
				newElement.setLabel(key);
				newElement.setTooltip(key);
				newElement.setType(ItemType.RADIO);
				if (key.equals(getScan().getCurrentGroup())) {
					newElement.setSelected(true);
				} else {
					newElement.setSelected(false);
				newElement.setContributionURI(CONTRIB_URI);
				newElement.setVisible(true);
				menu.getChildren().add(newElement);
Both, input and menu, are found.
Then all children (directmenuitems) should be cleared. If this is the second or higher run, the children are cleared if i take a look at menu in debug mode, but the menu and radio buttons are shown.
if more keys are available, at first run the labels and radios are shown and then only the radio buttons.
is there a function to "redraw" the menu or something like that?
Greetings,
Alex
[Updated on: Mon, 14 January 2013 05:30]
Report message to a moderator
Previous Topic:ParameterizedCommand not being executed after update to 4.3M4
Next Topic:eclipse 4 Application branding problem
Current Time: Sat May 25 13:06:16 EDT 2013
Powered by FUDForum. Page generated in 0.01607 seconds
