| [CDO] How to "flush" CDO Package registry ? [message #998592] |
Thu, 10 January 2013 05:10  |
laurent Mising name Messages: 22 Registered: September 2011 |
Junior Member |
Hi all,
I defined models and then generated CDO native packages.
Due to the fact that i struggled a bit to get these packages in CDO, I made several trials with different nsURI.
And I noticed that old, incorrect or deleted packages still appear in the CDO Package registry, which could lead to exceptions when there are different nsURI declared in the registry for a same package (old and new nsURI).
The only way I found to "flush" the old nsURI from the registry is to delete CDO content on server side (by removing the database directory content !).
Is there any better way ?
Laurent
| Re: [CDO] How to "flush" CDO Package registry ? [message #998615 is a reply to message #998592] |
Thu, 10 January 2013 05:54   |
Eike Stepper Messages: 5151 Registered: July 2009 |
Hi Laurent,
I'm confused by some of your terms, see below...
Am 10.01.2013 11:10, schrieb laurent Mising name:
> Hi all,
What do you mean by "get these packages in CDO"?
No matter what exactly you're trying to achieve, you must always use the nsURI that's generated into your package
interface and your plugin.xml.
What are those concepts? I haven't heard of them, yet.
No clue what old and new mean here. Maybe some concrete code would help me to understand.
Nothing in this sentence is clear to me: What is "flush"? What is "database directory content"?
Hard to tell :P
Cheers
/Eike
http://www.esc-net.de
| Re: [CDO] How to "flush" CDO Package registry ? [message #998629 is a reply to message #998615] |
Thu, 10 January 2013 06:29   |
Junior Member |
Hi Eike,
I'll try to better explain myself.
Using the CDO Sessions view from Eclipse, I open a new session connected to a so-called "repo1".
With a right-click on the opened session, I can open the package registry.
Now let's say that I defined an "application" model. I can generate the corresponding CDO native java code (application, application.impl, application.util packages) in my project source folder.
The corresponding nsURI is (by default) : http://application/1.0
Then I launch an eclipse application containing the generated plug-in and the necessary components to get the CDO Sessions view as well.
As I said before, I can connect to my repo1, open the package registry where I find my stuff (the package registered with its nsURI). And I can create a resource containing an application. No problem.
Now let's say I decide to change my nsURI to http://application
I generate my CDO native code all over again.
I also have to modify manually my plugin.xml which still have the previous nsURI...
I then launch my eclipse application again, connect to my repo1, open the package regitry and then... I find two entries for my application package. One with the former nsURI and another one with the modified nsURI.
When I try to open the editor on my previously created resource, I get an exception because my editor is still looking for the package corresponding to the first nsURI...
So the question is : how do I get rid (or "flush" ) this old reference (without deleting CDO database...).
Laurent
| Re: [CDO] How to "flush" CDO Package registry ? [message #998641 is a reply to message #998629] |
Thu, 10 January 2013 06:58  |
Am 10.01.2013 12:29, schrieb laurent Mising name:
> Hi Eike,
That's not allowed. By having committed the "old" package (with that specific nsURI) and some objects that rely on it
you've kind of "released" the package to the public (like API).
That has recently been fixed in EMF 2.9.
The one with the "old" nsURI is there because CDO always stores a copy of the dynamic model in the database. It's used
by the client if the original package is no longer available locally.
The (expected) effect is that you've got 2 packages with different nsURIs available.
I *think* that shouldn't happen. It's probably a rare problem because nobody really uses dynamic packages in production.
And in development you better start a new repository.
> So the question is : how do I get rid (or "flush" ;)) this old reference (without deleting CDO database...).
You can't.
Cheers
/Eike
FUDForum. Page generated in 0.01734 seconds
