Home » Modeling » EMF » EMF and SOAP - how?(How to use EMF generated classes for web services?)
EMF and SOAP - how? [message #998324] Wed, 09 January 2013 15:02 Go to next message
Anton Hughes is currently offline Anton Hughes
I'm new to EMF and, so far, and very impressed with it.
Especially xcore.
However, today I tried to use my generated code in a webservice and found that I couldnt.
This is surprising.
Are there any ways to easily change the generated classes so that they are compatible with SOAP?
Re: EMF and SOAP - how? [message #998358 is a reply to message #998324] Wed, 09 January 2013 16:31 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
He Anton,
You can also try the EMF subproject Texo, this project is targeted for web server/service environments (although more
using JSON/REST/XML approaches).
http://wiki.eclipse.org/Texo
http://martintaal.wordpress.com/2012/04/05/emf-texo-json-rest-web-service-support-connecting-your-client-to-an-emf-supporting-web-server/
gr. Martin
On 01/09/2013 09:02 PM, Anton Hughes wrote:
> Hi
> Especially xcore.
> This is surprising.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: EMF and SOAP - how? [message #998524 is a reply to message #998324] Thu, 10 January 2013 01:52 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Anton,
What does it mean to be compatible with SOAP? As I understand it, SOAP
is about producing/consuming XML, and Resources do that nicely.
On 09/01/2013 9:02 PM, Anton Hughes wrote:
> Hi
> Especially xcore.
> This is surprising.
Re: EMF and SOAP - how? [message #998585 is a reply to message #998524] Thu, 10 January 2013 04:54 Go to previous messageGo to next message
Hi Ed
I'm not sure what you mean by 'Resources'? Can you expand on this please?
Im referring to the generated classes - to use these as domain objects in web services, it seems they are not compatible.
Re: EMF and SOAP - how? [message #998598 is a reply to message #998585] Thu, 10 January 2013 05:23 Go to previous messageGo to next message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#FFFFFF">
Anton,<br>
<br>
Have a look at these:<br>
<blockquote><a
href="http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclipse.emf.doc/tutorials/xlibmod/xlibmod.html">Tutorial:
Generating an EMF Model using XML Schema</a><br>
<a target="_out"
href="http://www.theserverside.com/tt/articles/article.tss?l=BindingXMLJava">Binding
XML to Java</a><br>
</blockquote>
<br>
<div class="moz-cite-prefix">On 10/01/2013 10:54 AM, Anton Hughes
wrote:<br>
</div>
<blockquote cite="mid:kcm354$v1v$1@xxxxxxxxe.org" type="cite">Hi
Ed
<br>
<br>
please?
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
Re: EMF and SOAP - how? [message #998600 is a reply to message #998598] Thu, 10 January 2013 05:33 Go to previous messageGo to next message
Hi Ed
Your message came through as raw html - not the easiest to read. But I'm trying ... Smile
The links that you posted show how to use EMF generated classes with xml - but not soap.
It appears that the generated objects are not compatiable for as Soap objects.
Re: EMF and SOAP - how? [message #998611 is a reply to message #998600] Thu, 10 January 2013 05:47 Go to previous message
Anton,
I know SOAP as an XML-based interchange protocol, but I don't know what
it means to be a SOAP object. What are EMF objects missing in order to
be SOAP objects?
On 10/01/2013 11:33 AM, Anton Hughes wrote:
> Hi Ed
> I'm trying ... :)
> xml - but not soap.
> objects.
Previous Topic:Loading resource from jar file
Next Topic:[CDO] How to "flush" CDO Package registry ?
Current Time: Sat May 25 13:32:49 EDT 2013
Powered by FUDForum. Page generated in 0.01747 seconds
