Home » Eclipse Projects » BIRT » How does BIRT determine the jdbc resultset datatypes?
How does BIRT determine the jdbc resultset datatypes? [message #998512] Thu, 10 January 2013 01:25 Go to next message
phil rumble is currently offline phil rumble
I am implementing a new jdbc driver.
I would like to know how the BIRT dataset wizard tool determines the datatypes of the resultsets.
All my columns are determined to be of type BLOB, when I explicitly set them to VARCHAR.
For example some of the column metadata is ;
COLUMN_NAME = SAMPLETIME
TYPE_NAME = String
SQL_DATA_TYPE = 12
DATA_TYPE = 12
COLUMN_SIZE = 255
COLUMN_DEF = ""
I am missing something that BIRT needs for jdbc. I seek assistance.
Thanks in advance
Rumble
Re: How does BIRT determine the jdbc resultset datatypes? [message #998947 is a reply to message #998512] Thu, 10 January 2013 21:45 Go to previous message
Michael Williams is currently offline Michael Williams
The best thing to do would probably be to download the source.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Property binding and dynamic paramaters
Next Topic:Best Practice of How to Manage reports from different Environments? Dev, QA and Prod?
Current Time: Sat May 18 04:39:07 EDT 2013
Powered by FUDForum. Page generated in 0.01490 seconds
