Home » Language IDEs » CDT » Using CDT's Abstract Syntax Tree to write code?
Using CDT's Abstract Syntax Tree to write code? [message #997115] Thu, 03 January 2013 13:49 Go to next message
Erika Redmark is currently offline Erika Redmark
I've been able to properly use the abstract syntax tree APIs in CDT for parsing pre-existing C code in my program. However, I can't seem to find any examples on doing the reverse, (creating an AST programmatically and turning it into source code), so I am wondering if this is even possible. I would like to use an AST to generate code as it seems like it would make the process extremely easy.
If it is indeed possible, then what would be a starting point for using the API to generate an AST, and then source code from it? (Preferably no internal/deprecated methods)
- Erika
Re: Using CDT's Abstract Syntax Tree to write code? [message #998188 is a reply to message #997115] Wed, 09 January 2013 09:27 Go to previous message
Just in case anyone stumbles on this topic, I didn't get an answer here but got one on StackOverflow, Which I can't link to because I don't have enough messages (google "Using CDT's Abstract Syntax Tree API to generate/write C code?")
It's not a 'solve everything' answer but it seems a good starting point.
Previous Topic:Getting Started
Next Topic:phortran breakpoints ignored
Current Time: Thu May 23 01:22:01 EDT 2013
Powered by FUDForum. Page generated in 0.01641 seconds
