Home » Modeling » GMF (Graphical Modeling Framework) » Assign File to a GMF node
Assign File to a GMF node [message #997705] Tue, 08 January 2013 10:21 Go to next message
Phil H is currently offline Phil H
Member
I would like to assign a file to a GMF node.
For example, there is a node Person A and I would like to assign a excel file to this person. Hope you understand what I mean.
I know that I could use a String with the filepath, but I wouldn't reckon that this is a good solution. I also thougt about a folder inside the project folder where I could store the files and assign only the filename to the node.
Has anyone maybe another solution?
Phil
Re: Assign File to a GMF node [message #998128 is a reply to message #997705] Wed, 09 January 2013 07:25 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
it depends on your IT infrastructure and use cases on how to solve your problem best.
Ralph
Re: Assign File to a GMF node [message #999941 is a reply to message #998128] Sun, 13 January 2013 09:06 Go to previous message
Member
Thx for your answer so far.
What do you mean with IT Infrastructure?
It doesn't matter which file extension it is. I just want to have the ability to assign Files to nodes in my GMF Editor. Furthermore, they should be stored somewhere in my project folder, because I want to be able to exchange Projects from one pc to another pc.
Hope you understand what I mean? I'm not sure if there is a good solution for my problem so far..
Previous Topic:Compartment layout problem after update to Juno
Next Topic:Display ports that are not contained by object
Current Time: Sun May 26 01:19:03 EDT 2013
Powered by FUDForum. Page generated in 0.01753 seconds
