Home » Eclipse Projects » JFace » How do I open a file from my table with a button click?
How do I open a file from my table with a button click? [message #997745] Tue, 08 January 2013 11:53 Go to next message
James Teater is currently offline James Teater
The Table Viewer is created and displayed in a Dialog Class. The columns and button creation is in a TableViewer class.
I have added a column in my JFace table that is populated with buttons. I have tried to insert a image of the table with no luck. So I will try my best to explain the table.
____________________________________________________________
|Date________|_____Item______|____Filename_____|_____button|
|01/09/13....|.....metal.....|...metal.pdf.....|....[adobe]|
|01/09/13....|.....metal01...|...metal01.pdf...|....[adobe]|
|01/09/13....|.....metal02...|...metal02.pdf...|....[adobe]|
I want the corresponding file open when the user clicks the button in the same row.
Column / Button Code
case 6:
                   Map<Object, Button> buttons = new HashMap<Object, Button>();
                   TableItem item = (TableItem) cell.getItem();
                   Button button;
                   if(buttons.containsKey(cell.getElement())) {
                      button = buttons.get(cell.getElement());
                   else
                     button = new Button((Composite) cell.getViewerRow().getControl(),SWT.PUSH);
                     //button.setText("Adobe");
                     button.setImage(loadImage("/images/AdobeIcon.png"));
                     buttons.put(cell.getElement(), button);
                   TableEditor editor = new TableEditor(item.getParent());
                   editor.grabHorizontal  = true;
                   editor.grabVertical = true;
                   editor.setEditor(button , item, cell.getColumnIndex());
                   button.addListener(SWT.Selection, new SelectionListener(item, button, cell.getElement()));
                   editor.layout();
Selection Listener Class Code
class SelectionListener implements Listener {
      TableItem item;
      Button editButton;
      Object element;
      //                         Constructor                                  //
      public SelectionListener(TableItem item, Button editButton, Object element) {
          this.item = item;
          this.editButton = editButton;
          this.element = element;
      //                         handleEvent                                  //
      public void handleEvent(Event event) {
         AplotSaveDataModel.SaveData selected = (( AplotSaveDataModel.SaveData)element);
         int index = AplotSaveDataModel.getInstance().getIndexOf(selected);
         final File viewerFile = new File(AplotSaveDataModel.getInstance().getSelectedPDFFileName(index));
         try {
            Desktop.getDesktop().open(viewerFile);
         catch (IOException e) {
           e.printStackTrace();
This value does change when a differnt row is clicked
Allways Returns 0
This is the getIndexOf method in AplotSaveDataModel
public int getIndexOf(SaveData selected) {
       return data.indexOf(selected); //data is a arraylist
I think that the above method may be the issue.
What is happening - It does not matter which button is clicked. The file in row 0 is always opened, because the index it always return 0
I am wondering if data.indexOf(selected) returns 0 is element is found and -1 if not.
I would be glad to change the code above, if there is a easier way to preform what is needed. I just want when the button is clicked the file opens that is in the same row has the button.
Thanks in advance for any help you can give me.
Re: How do I open a file from my table with a button click? [message #998115 is a reply to message #997745] Wed, 09 January 2013 06:59 Go to previous message
Timur Achmetow is currently offline Timur Achmetow
Member
I would you suggest to work wie JFace TableViewer and EditingSupport.
Create for each row - if you needed - an editing support, which you allows to edit each row.
Examples see here: http://www.vogella.com/articles/EclipseJFaceTableAdvanced/article.html#jfaceeditor
Previous Topic:How to display ToolTip on Mouse Hover over VerticalRuler
Next Topic:How alignment done in this UI
Current Time: Sat May 25 23:09:58 EDT 2013
Powered by FUDForum. Page generated in 0.01600 seconds
