Home » Eclipse Projects » Vex » VEX installed - WHAT NEXT??(No start files, no wizards MAC OS X)
VEX installed - WHAT NEXT?? [message #989890] Sun, 09 December 2012 10:22 Go to next message
Thomas W. Richter is currently offline Thomas W. Richter
I have installed VEX on my MAC. Everything seems to be ok. Installation ok and so on.
BUT:
Reading http://wiki.eclipse.org/Vex/UserGuide there is no "Authoring section", no samples to see.
What went wrong????
BG TWR
Re: VEX installed - WHAT NEXT?? [message #990075 is a reply to message #989890] Mon, 10 December 2012 13:10 Go to previous messageGo to next message
Florian Thienel is currently offline Florian Thienel
Hi Thomas,
I added some screenshots to the Vex User Guide. If you cannot find the shown entry of the "New" wizard, something went wrong with your Vex installation. In this case, you should have a look into "Help > About Eclipse > Installation Details" if you can find any evidence of Vex.
Best Regards,
Florian
Re: VEX installed - WHAT NEXT?? [message #995661 is a reply to message #990075] Sun, 30 December 2012 15:17 Go to previous messageGo to next message
but I fear there is nothing useful to do with the Editor...
For example:
Add Element
To insert a new element at the current cursor position or - in the case if something is selected - to surround the selected text or fragment with a new element:
Choose Document | Add | Element... (or hit Ctrl+Space)
In the content assist which pops up choose the element to add by one of the following possibilities:
Use Up and Down keys to select element and hit Return
Click on the element to add
To filter the list of elements type the name or a part of the name and hit Return to add the topmost element
Tip: To place the cursor at the proper position (e.g. a new chapter between two existing chapters in DocBook) see the path which is shown in the status bar.
Where do I find such a command????? Neither in a menu nor in context mouse menu there is any hint of Document....
How can I convert a file? I found absolutely NOTHING. Ctrl-Space? Didn't work.
Eh... by the way: I am using Mac, no Windows...
My conclusion for now: a good idea but without any useful doc not useful at all. Unfortunately...
BR
TWR
[Updated on: Sun, 30 December 2012 15:17]
Report message to a moderator
Re: VEX installed - WHAT NEXT?? [message #997667 is a reply to message #995661] Sun, 06 January 2013 03:59 Go to previous message
Thomas,
thank you for that straight feedback. This helps us to focus on the
really important things. As a first step we will create a screencast for
the "getting started" use case (bug 397451).
Just to be sure: did you try "[Apple]-Space" instead of Ctrl-Space?
Florian
Am 30.12.2012 21:17, schrieb Thomas W. Richter:
> Thank,
> For example:
> Quote:
>> Add Element
>> in the status bar.
> work.
> BR
> TWR
Previous Topic:Creating a DITA topic; DITA attribute editing
Next Topic:custom key bindings for editing in vex?
Current Time: Thu May 23 19:32:42 EDT 2013
Powered by FUDForum. Page generated in 0.06627 seconds
