Home » Eclipse Projects » Buckminster » qualifier.replacement does not work in the IDE?
qualifier.replacement does not work in the IDE? [message #995972] Mon, 31 December 2012 12:26 Go to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
when I run buckminster headless qualifier replacement takes place
automatically with something like
1.0.0.201212301738
in the IDE I use a properties file which contains
qualifier.replacement.*=generator:buildTimestamp
generator.buildTimestamp.format=yyyyMMddHHmm
but when I run site.p2 action in the IDE I get an error
org.eclipse.core.runtime.CoreException:
<myeclipsedir>/configuration/org.eclipse.osgi/bundles/557/1/.cp/org/eclipse/buckminster/pde/antscripts/build.xml:300:
java.lang.IllegalArgumentException: Format
"format(n[.n=0;[.n=0;[.S=[A-Za-z0-9_-];='';]]])" was unable to parse
1.0.0.201212311725
am I doing something wrong?
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: qualifier.replacement does not work in the IDE? [message #997267 is a reply to message #995972] Fri, 04 January 2013 15:23 Go to previous messageGo to next message
Alex Kravets is currently offline Alex Kravets
Try generator.buildTimestamp.format=yyyyMMdd-HHmm because the timestamp 1.0.0.201212311725 is a combination of date and time.
Re: qualifier.replacement does not work in the IDE? [message #997660 is a reply to message #997267] Sun, 06 January 2013 12:02 Go to previous messageGo to next message
this seems to work
generator.buildTimestamp.format='v'yyyyMMdd-HHmm
Re: qualifier.replacement does not work in the IDE? [message #997661 is a reply to message #995972] Mon, 07 January 2013 07:30 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas Hallgren
Hi Lorenzo,
Sorry for late reply. I don't understand what could cause this error.
You're not doing anything out of the ordinary and the qualifier is
valid. Would it be possible for you to provide a sample that reproduces
the problem that I could look at?
A full stacktrace might be helpful if that's possible to obtain.
- thomas
On 2012-12-31 18:26, Lorenzo Bettini wrote:
> Hi
> 1.0.0.201212301738
> 1.0.0.201212311725
> cheers
> Lorenzo
Re: qualifier.replacement does not work in the IDE? [message #997663 is a reply to message #997661] Tue, 08 January 2013 07:09 Go to previous message
Hi Thomas
probably something was somehow spoiled in my workspace when I tried
that, since now
works as expected
sorry for the noise :)
cheers
Lorenzo
On 01/07/2013 01:30 PM, Thomas Hallgren wrote:
> Hi Lorenzo,
> - thomas
>> Hi
>> 1.0.0.201212301738
>> 1.0.0.201212311725
>> cheers
>> Lorenzo
Previous Topic:swt error - has anybody seen that?
Next Topic:Site.p2-generated product includes launcher source bundle
Current Time: Tue May 28 23:38:23 EDT 2013
Powered by FUDForum. Page generated in 0.01547 seconds
