Home » Eclipse Projects » Remote Application Platform (RAP) » RAP focus after shell setVisible(Shell/Field focus after shall is made visible again)
RAP focus after shell setVisible [message #997248] Fri, 04 January 2013 12:03 Go to next message
John Gymer is currently offline John Gymer
Member
Another focus-related query related to RAP vs SWT...
I have a couple of Shells, one of which is made hidden with shell.setVisible(false) previously.
Now in a later event handler I need to make that shell visible again, make it active (bring it to front of Z order of Shells) and give a specific widget on it the keyboard focus.
Here is the code to make it visible again:
myShell.setVisible(true);
myShell.forceActive();
myText.setFocus();
The result is that the Shell becomes visible again, but the forceActive does not bring it to the front of the Z-Order. The setFocus on the Text widget works ok, putting the caret into that field, which looks really wierd if the 2 Shells overlap - you see the cursor blinking through the other Shell! Essentially you have keyboard focus to a non-active Shell, which might be placed behind another Shell.
If I tweak the code a little, I can successfully bring the other Shell to focus using:
myShell.forceFocus();
However, if I add myText.setFocus() back in at the end, then the myShell.forceFocus() is not honoured... sort of makes sense since we are referring to keyboard input here, not Z-Order.
So, to my eye it appears to be a bug that forceActive() on the Shell does not appear to have any effect in RAP... or am I missing the point somewhere?!
By the way, I'm using Nightly 2013/01/03 RAP 2.0 M4, Nightly ClientScripting etc. etc.
Thanks, John
Just because you can doesn't mean you should
Re: RAP focus after shell setVisible [message #997624 is a reply to message #997248] Fri, 04 January 2013 13:28 Go to previous message
Tim Buschtoens is currently offline Tim Buschtoens
Hi.
If you would open a bugzilla entry and attach a snippet (EntryPoint)
that demonstrates your issue, that would be perfect.
Greetings,
Tim
Tim Buschtöns
Twitter: @EclipseRAP
Previous Topic:ClientScripting VerifyListener determine keystroke
Next Topic:HttpSession Listener
Current Time: Sat May 25 10:54:32 EDT 2013
Powered by FUDForum. Page generated in 0.01484 seconds
