Home » Eclipse Projects » Eclipse Platform » Out of memory after Clean-Autobuild multiple times with custom builder by org.eclipse.core.internal.
| Out of memory after Clean-Autobuild multiple times with custom builder by org.eclipse.core.internal. [message #994454] |
Thu, 27 December 2012 05:52  |
maarten meijer Messages: 141 Registered: July 2009 |
I created a builder to validate photometric data files (IES/EULUMDAT).
On full or incremental build the file is parsed, checked and markers are
added to the file.
On clean I remove all markers with
getProject().deleteMarkers(markerType, true, IResource.DEPTH_INFINITE);
After creating a test fragment to stress test the builder by doing a
clean and having autobuild rebuild the project a fixed number of times,
the memory fills up and then I get an java.lang.OutOfMemoryError: Java
heap space
My expectation was that after a Clean command and an auto rebuild I end
up with the same amount of memory consumed. I.e clean/rebuild should
have same or less memory used than before.
I run against a target platform consisting of platform 3.8.1, GEF 3.8.1,
and my plugin set.
I monitored the project with jvisualvm and analyzed heap dumps with the
Eclipse Memeory Analyzer tool. I closed a few undetected resource leaks,
even simplified the builder to just set one marker, but this keeps
happening.
I already found ways to eliminate the duplicate Strings I had.
Whatecver I try the heap just fills up.
org.eclipse.core.internal.resources.SaveManager consumes 84% of memory!!
then it creshes.
What can I do to get rid of this?
Maarten Meijer
Top 5 shallow heap
Class Name | Objects | Shallow Heap
| Retained Heap
char[] | 424,786 | 38,555,688
| 38,555,688
org.eclipse.core.internal.resources.ResourceInfo| 391,601 | 25,062,464
| 58,151,752
java.lang.String | 451,449 | 14,446,368
| 52,650,496
java.lang.Object[] | 203,315 | 9,751,960
| 11,410,808
org.eclipse.core.internal.dtree.DataDeltaNode | 379,513 | 9,108,312
| 111,850,096
Top 5 retained heap
Shallow Heap | Retained Heap
org.eclipse.core.internal.dtree.AbstractDataTreeNode[]| 281 |
1.633.528 | 115.006.776
org.eclipse.core.internal.dtree.DataDeltaNode | 379.513 |
9.108.312 | 111.850.096
org.eclipse.core.internal.resources.ResourceInfo | 391.601 |
25.062.464 | 58.151.752
java.lang.String | 451.449 |
14.446.368 | 52.650.496
char[] | 424.786 |
38.555.688 | 38.555.688
Top 5 dominator tree
Class Name |
Shallow Heap | Retained Heap | Percentage
org.eclipse.core.internal.resources.SaveManager @ 0x7f5bbf8a0 |
64 | 111.120.768 | 84,23%
org.eclipse.core.internal.resources.Workspace @ 0x7f56e45f0 |
152 | 3.349.672 | 2,54%
org.eclipse.core.internal.dtree.DeltaDataTree @ 0x7f5032950 |
24 | 1.695.864 | 1,29%
org.eclipse.core.internal.registry.RegistryObjectManager @ 0x7f5875a80|
64 | 1.581.096 | 1,20%
sun.net.www.protocol.jar.URLJarFile @ 0x7f552fc58 |
72 | 476.120 | 0,36%
| Re: Out of memory after Clean-Autobuild multiple times with custom builder by org.eclipse.core.inter [message #997602 is a reply to message #994454] |
Tue, 08 January 2013 08:16   |
Dani Megert Messages: 3801 Registered: July 2009 |
> are added to the file.
> times, the memory fills up and then I get an
> java.lang.OutOfMemoryError: Java heap space
This looks like a leak somewhere. Best would be to create a small sample
with your build and then file a bug against Platform Resources.
Dani
> end up with the same amount of memory consumed. I.e clean/rebuild
> should have same or less memory used than before.
> 3.8.1, and my plugin set.
> the Eclipse Memeory Analyzer tool. I closed a few undetected resource
> leaks, even simplified the builder to just set one marker, but this
> keeps happening.
> memory!! then it creshes.
> Maarten Meijer
> Top 5 shallow heap
> | 38,555,688
> | 58,151,752
> | 52,650,496
> | 11,410,808
> | 111,850,096
> Top 5 retained heap
> char[] | 424.786 |
> Class Name
> 0x7f5875a80| 64 | 1.581.096 | 1,20%
| Re: Out of memory after Clean-Autobuild multiple times with custom builder by org.eclipse.core.inter [message #1000402 is a reply to message #997602] |
Mon, 14 January 2013 12:06  |
Created bug 398104: Out of memory error on repeated Clean for builder
https://bugs.eclipse.org/bugs/show_bug.cgi?id=398104
Maarten
> Dani
Current Time: Fri May 24 22:13:02 EDT 2013
Powered by FUDForum. Page generated in 0.02628 seconds
