Home » Language IDEs » CDT » Can't add a new build configuration
Can't add a new build configuration [message #997353] Sun, 06 January 2013 15:28 Go to next message
Chris Bruniges is currently offline Chris Bruniges
Hi all,
I'm trying to add a new build configuration to some existing C projects. I can get to the configuration manager, through project properties->manage configurations, but when I click new, nothing happens, and the error log shows the following new error.
Any ideas what's going wrong, and how it can be fixed without reconfiguring (as in scorched earth) the project (the project is shared between a group of developers, who already groan about using eclipse, so I'm trying to avoid rebuilding the project configuration).
	at java.lang.Integer.decode(Integer.java:927)
	at org.eclipse.cdt.managedbuilder.internal.core.Builder.decodeParallelizationNumber(Builder.java:641)
	at org.eclipse.cdt.managedbuilder.internal.core.Builder.loadFromProject(Builder.java:803)
	at org.eclipse.cdt.managedbuilder.internal.core.Builder.<init>(Builder.java:235)
	at org.eclipse.cdt.managedbuilder.internal.core.ToolChain.<init>(ToolChain.java:276)
	at org.eclipse.cdt.managedbuilder.internal.core.FolderInfo.<init>(FolderInfo.java:141)
	at org.eclipse.cdt.managedbuilder.internal.core.Configuration.<init>(Configuration.java:417)
	at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.load(ConfigurationDataProvider.java:373)
	at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.loadConfiguration(ConfigurationDataProvider.java:548)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.loadData(CProjectDescriptionManager.java:1144)
	at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:130)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:194)
	at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:493)
	at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:235)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:436)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:418)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:412)
	at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:405)
	at org.eclipse.cdt.core.model.CoreModel.getProjectDescription(CoreModel.java:1422)
	at org.eclipse.cdt.managedbuilder.ui.properties.NewCfgDialog.getImportItems(NewCfgDialog.java:598)
	at org.eclipse.cdt.managedbuilder.ui.properties.NewCfgDialog.access$32(NewCfgDialog.java:593)
	at org.eclipse.cdt.managedbuilder.ui.properties.NewCfgDialog$LocalDialog.createDialogArea(NewCfgDialog.java:304)
	at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java:760)
	at org.eclipse.jface.window.Window.create(Window.java:431)
	at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
	at org.eclipse.jface.window.Window.open(Window.java:790)
	at org.eclipse.cdt.managedbuilder.ui.properties.NewCfgDialog.open(NewCfgDialog.java:405)
	at org.eclipse.cdt.ui.newui.ManageConfigDialog.handleNewPressed(ManageConfigDialog.java:173)
	at org.eclipse.cdt.ui.newui.ManageConfigDialog$3.widgetSelected(ManageConfigDialog.java:136)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:248)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
	at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
	at org.eclipse.jface.window.Window.open(Window.java:801)
	at org.eclipse.cdt.ui.newui.ManageConfigRunner.manage(ManageConfigRunner.java:62)
	at org.eclipse.cdt.ui.newui.AbstractPage$2.widgetSelected(AbstractPage.java:296)
	at org.eclipse.ui.dialogs.PropertyDialogAction.run(PropertyDialogAction.java:158)
	at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
	at org.eclipse.jface.commands.ActionHandler.execute(ActionHandler.java:119)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
	at sun.reflect.GeneratedMethodAccessor31.invoke(Unknown Source)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:276)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:494)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:545)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:366)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:313)
	at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:82)
	at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1483)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1275)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1285)
	at org.eclipse.swt.widgets.Control.traverse(Control.java:4946)
	at org.eclipse.swt.widgets.Control.translateTraversal(Control.java:4924)
	at org.eclipse.swt.widgets.Composite.translateTraversal(Composite.java:1549)
	at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control.java:3047)
	at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Composite.java:741)
	at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1758)
	at org.eclipse.swt.widgets.Control.windowProc(Control.java:5116)
	at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:3459)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:4369)
	at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
	at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:8307)
	at org.eclipse.swt.widgets.Display.eventProc(Display.java:1192)
	at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
	at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2332)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3177)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Re: Can't add a new build configuration [message #997359 is a reply to message #997353] Sun, 06 January 2013 20:06 Go to previous message
Andrew Gvozdev is currently offline Andrew Gvozdev
This was fixed not far ago for upcoming CDT 8.1.2. Try updating to the latest build from juno nightly build site http://download.eclipse.org/tools/cdt/builds/juno/nightly
Previous Topic:How to enable code completion for tuple
Next Topic:Unresolved includes issue
Current Time: Thu May 23 12:21:32 EDT 2013
Powered by FUDForum. Page generated in 0.03569 seconds
