| Documenting UML elements in Papyrus [message #695908] |
Tue, 12 July 2011 15:53  |
Jay Billings Messages: 36 Registered: July 2011 |
Member |
I was working with Papyrus in Helios the other day and I could not find a way to document a UML element. So, for example, if you click on a class in a diagram, all sorts of properties are displayed, but there is no where that I could type a description of that class. Another pertinent example would be an operation on a class - what if I want to add some documentation to just that operation and not the rest of the class?
Am I missing something critical here?
I could accomplish this using a note, but the result is a diagram full of notes and I can't access the documentation in a transformation to code.
Jay Jay Billings
Oak Ridge National Laboratory
Twitter: @jayjaybillings
| Re: Documenting UML elements in Papyrus [message #947980 is a reply to message #947773] |
Wed, 17 October 2012 12:29   |
Christian W. Damus Messages: 551 Registered: July 2009 |
Hi, Keith,
This is the Show View menu, not the dialog.
What do you see when you choose the "Other..." option to open the Show
View dialog?
If you don't see the Documentation view in there, then you might check
the workspace log for any messages indicating that there's something
wrong with that view contribution, or that the plug-in that contributes
it has unresolved dependencies, or something.
HTH,
Christian
On 2012-10-17 12:20:29 +0000, Keith Dorking said:
> Hi Christian,
> No unfortunately I do not see "Documentation" in the Show View dialog..
> I have uploaded a screen capture of what I do see in the Show View
> dialog.
> Cheers,
> Keith
> <image>
FUDForum. Page generated in 0.25596 seconds
