Home » Eclipse Projects » BIRT » set dataset parameters in runtime (set dataset parameters in runtime )
set dataset parameters in runtime [message #997297] Sat, 05 January 2013 01:05 Go to next message
Naveen Goyal is currently offline Naveen Goyal
I have created a BIRT report layout... The user makes three enteries, startDate, EndDate and user selects a processName (via dropDown)...
Now I have a datasetQuery named Data Set1 like... select * from Table1 where col1=? AND col2=? AND col3=?...
Now after he press a button, I want to pass the three selected elements as parameter to the dataset and execute it to set its output parameters to a table
(I have mapped dataset output parameters to table).
reportParameter makes a pop-up as we run the report initially but I dont want it... as I want resultSet only for the elements value entered by user...
Thanks in advance...
Re: set dataset parameters in runtime [message #997518 is a reply to message #997297] Mon, 07 January 2013 18:52 Go to previous message
Michael Williams is currently offline Michael Williams
I'm not sure I'm understanding completely. Does the user select values from the standard BIRT parameter page? Or is that part of your report's layout? Let me know.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Report items from library is not shown
Next Topic:Fill pdf page with table / vertical lines + transport totals
Current Time: Fri May 24 02:32:00 EDT 2013
Powered by FUDForum. Page generated in 0.01518 seconds
