| SVN + Hudson on Eclipse [message #997290] |
Fri, 04 January 2013 19:24 |
Ricardo Balduino Messages: 191 Registered: July 2009 |
Hi, I'm trying to make Hudson + SVN work on Eclipse. I have successfully installed Hudson and SVN servers, and their admin interfaces are accessible.
I installed the Subversive plugin in Eclipse so I can access SVN repository successfully, and I can see Hudson build results from inside Eclipse, but I'm not sure I'm running builds correctly.
The problem is that I haven't been able to generate builds in Hudson in sync with source code changes done in my simple Java project in Eclipse.
I may be missing some initialization on the Hudson side. Are there any tutorials, or even better examples showing the integration of these tools?
Any help will be appreciated.
Configuration:
Eclipse Juno SR1
SVN 1.7
Hudson 3.0
Windows 7
Thanks!
FUDForum. Page generated in 0.01635 seconds
