Home » Modeling » TMF (Xtext) » Formatter problem
Formatter problem [message #997111] Thu, 03 January 2013 13:29 Go to next message
Robert Wild is currently offline Robert Wild
using this minimalistic grammar
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl ""
Model:
	(includes+=Include)*
	(greetings+=Element)+;
Element:
	Greeting | Farewell
Greeting:
	'Hello' name=ID '!';
Farewell:
	'Bye' name=ID '!'
Include:
	"include" name=ID";"
and this formatter
public class MyDslFormatter extends AbstractDeclarativeFormatter {
	protected void configureFormatting(FormattingConfig c) {
		MyDslGrammarAccess f = (MyDslGrammarAccess) getGrammarAccess();
		c.setLinewrap(2).around(f.getElementRule());
the formatter works only correctly if at least one include is defined. I don't understand why. Can somebody shed some light on this?
The results after formatting are:
include Name ;
Hello rob !
Hello Name !
Bye rob !
and
Hello rob ! Hello Name ! Bye rob !
Re: Formatter problem [message #997114 is a reply to message #997111] Thu, 03 January 2013 13:41 Go to previous message
if I remove Include from the grammar the formatting won't work at all. Is this a bug or do I just not understand what's going on?
Previous Topic:Xtext grammar for real literals and filenames with a . dot extension
Next Topic:junit test formatting removes hidden tokens (i.e. comments)
Current Time: Fri May 24 20:08:18 EDT 2013
Powered by FUDForum. Page generated in 0.04048 seconds
