Home » Eclipse Projects » Eclipse 4 » Decorating tab icons (Is there a best practice for decorating tab icons in e4)
Decorating tab icons [message #977862] Fri, 09 November 2012 11:40 Go to next message
Greg Babcock is currently offline Greg Babcock
My application edits an EMF model and does not use the Resources API. In 3.x the EditorPart has access direct access to the image so decorating tab icons was straight forward.
There does not appear to be a way to decorate tab icons out of the box in e4 (this would be a nice enhancement Smile). I looked at how the compatibility layer decorates icons but it doesn't seem like the right approach. I am thinking about providing a list of decorator URLs in the model via the context and then modifying the renderer to decorate icons. Am I on the right track?
[Updated on: Fri, 09 November 2012 11:41]
Report message to a moderator
Re: Decorating tab icons [message #980188 is a reply to message #977862] Sun, 11 November 2012 07:37 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
You can set the icon to a specific image by placing aN entry in the MPart's transient data using the IPresentationEngine.OVERRIDE_ICON_IMAGE_KEY.
Brian.
Re: Decorating tab icons [message #982099 is a reply to message #977862] Mon, 12 November 2012 18:37 Go to previous messageGo to next message
Thank you for your advice.
I was not successful setting the tab image using:
part.getTransientData().put(IPresentationEngine.OVERRIDE_ICON_IMAGE_KEY, image);
Are any addons required to make this work?
Re: Decorating tab icons [message #987991 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Sorry Greg -- as you discovered, this doesn't work on pure E4. I'm putting together a patch to fix this for 4.3.
Brian.
Re: Decorating tab icons [message #987994 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988021 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988022 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988038 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988039 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988055 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988056 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988073 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988074 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988093 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988094 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988112 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988113 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988135 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988136 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988158 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988159 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988177 is a reply to message #982099] Wed, 28 November 2012 12:40 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988178 is a reply to message #982099] Wed, 28 November 2012 12:41 Go to previous messageGo to next message
Brian.
Re: Decorating tab icons [message #988339 is a reply to message #987994] Thu, 29 November 2012 08:21 Go to previous messageGo to next message
I hope those repeat posts makes it clear that I am *very* sorry.
Re: Decorating tab icons [message #988393 is a reply to message #988339] Thu, 29 November 2012 12:31 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
Also we are waiting for your 15 patches.
Re: Decorating tab icons [message #988421 is a reply to message #988393] Thu, 29 November 2012 15:41 Go to previous messageGo to next message
Thank you, 4.3 is soon enough for me.
I am just building an app to learn e4 and develop methods for implementing features I currently use in 3.x.
Re: Decorating tab icons [message #996897 is a reply to message #977862] Thu, 03 January 2013 01:22 Go to previous message
Charles Jarowski is currently offline Charles Jarowski
It will be better if you could able to show some demo of it, I mean just wanted to see how it looks.
Previous Topic:Port to E4 roadmap?
Next Topic:How to set/modify the style of the application window
Current Time: Fri May 24 10:17:49 EDT 2013
Powered by FUDForum. Page generated in 0.02436 seconds
