Home » Eclipse Projects » EPF » change EPF(modify EPF )
change EPF [message #986471] Tue, 20 November 2012 10:11 Go to next message
robinson arias muñoz is currently offline robinson arias muñoz
hello guys need to know if I can change epf, to create other elements and their templates to generate and publish.
I have the source code of EPF and I document a use case, actor worker, activity diagram. this can be done?
I also want to know if I can change the model to one that I do.
Thank you.
Re: change EPF [message #996748 is a reply to message #986471] Wed, 02 January 2013 15:30 Go to previous messageGo to next message
Bruce MacIsaac is currently offline Bruce MacIsaac
I'm not sure I understand what you are trying to do. You may be interested to know that with Rational Method Composer (which is built on top of EPF) you can define custom user-defined types, and modify existing types to add new attributes and relationships.
That may fit your needs.
Re: change EPF [message #1029297 is a reply to message #996748] Fri, 29 March 2013 09:03 Go to previous message
Gabriel Hu is currently offline Gabriel Hu
Bruce,
How can I add in RMC new relations and defined new types.
For example I want to add to a task in the roles section Accountable role.
Thanks.
Previous Topic:Can't figure how to publish a Delivery Process
Next Topic:RMC - publish HTML through command line help
Current Time: Sat May 25 01:45:11 EDT 2013
Powered by FUDForum. Page generated in 0.01888 seconds
