Unable to open a workspace [message #916910] |
Wed, 19 September 2012 12:21  |
Ivan Galicia Messages: 7 Registered: September 2012 |
Junior Member |
I can not open a specific workspace. I need your help to fix the problem!
Here's part of the log:
!ENTRY org.eclipse.mylyn.tasks.core 4 0 2012-09-19 10:47:43.110
!MESSAGE Task activity monitor failed to load for extension contributed by org.eclipse.mylyn.context.tasks.ui
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "org.eclipse.mylyn.context.tasks.ui" was unable to instantiate class "org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:186)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.mylyn.internal.tasks.ui.util.TasksUiExtensionReader.loadTaskActivityMonitor(TasksUiExtensionReader.java:650)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:593)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:711)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:702)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:683)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:381)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:300)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:440)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:263)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:469)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:395)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:464)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1212)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:52)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:269)
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableExtension(EarlyStartupRunnable.java:117)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartupRunnable.java:66)
at org.eclipse.ui.internal.Workbench$52.run(Workbench.java:2357)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.NullPointerException
at org.eclipse.mylyn.internal.context.core.ContextCorePlugin.getContextManager(ContextCorePlugin.java:205)
at org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor.<init>(TaskActivityMonitor.java:96)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 37 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2012-09-19 10:47:43.111
!MESSAGE Plug-in "org.eclipse.mylyn.context.tasks.ui" was unable to instantiate class "org.eclipse.mylyn.internal.context.tasks.ui.TaskActivityMonitor".
!STACK 0
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-09-19 10:47:43.124
!MESSAGE Task list initialization failed
!STACK 0
at org.eclipse.mylyn.internal.context.tasks.ui.TaskContextStore.setDirectory(TaskContextStore.java:232)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.initializeDataSources(TasksUiPlugin.java:874)
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.start(TasksUiPlugin.java:625)
!ENTRY org.eclipse.mylyn.tasks.ui 4 0 2012-09-19 10:47:43.135
!MESSAGE Task list stop terminated abnormally
!STACK 0
at org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.stop(TasksUiPlugin.java:787)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:771)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:764)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:510)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1207)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:693)
at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
!ENTRY org.eclipse.mylyn.monitor.ui 4 0 2012-09-19 10:47:43.141
!MESSAGE Monitor UI stop failed
!STACK 0
at org.eclipse.mylyn.internal.monitor.ui.ActivityContextManager.stop(ActivityContextManager.java:152)
at org.eclipse.mylyn.internal.monitor.ui.MonitorUiPlugin.stop(MonitorUiPlugin.java:157)
!ENTRY org.eclipse.dltk.launching 2 4 2012-09-19 10:47:43.832
!MESSAGE Failed to resolve library locations for ruby.exe with C:\Temp\galiciai\dltk12063.tmp\scripts\path.rb
!STACK 0
java.lang.Exception: Output:
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType$2.run(AbstractInterpreterInstallType.java:719)
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType.runLibraryLookup(AbstractInterpreterInstallType.java:428)
at org.eclipse.dltk.internal.launching.AbstractInterpreterInstallType.getDefaultLibraryLocations(AbstractInterpreterInstallType.java:776)
at org.eclipse.dltk.launching.ScriptRuntime.getLibraryLocations(ScriptRuntime.java:978)
at org.eclipse.dltk.launching.ScriptRuntime.getLibraryLocations(ScriptRuntime.java:966)
at org.eclipse.dltk.internal.launching.InterpreterContainer.computeBuildpathEntries(InterpreterContainer.java:135)
at org.eclipse.dltk.internal.launching.InterpreterContainer.getBuildpathEntries(InterpreterContainer.java:118)
at org.eclipse.dltk.internal.launching.InterpreterContainer.computeBuildpathEntries(InterpreterContainer.java:221)
at org.eclipse.dltk.internal.launching.InterpreterContainer.getBuildpathEntries(InterpreterContainer.java:215)
at org.eclipse.dltk.internal.core.ModelManager.containerPutIfInitializingWithSameEntries(ModelManager.java:2065)
at org.eclipse.dltk.core.DLTKCore.setBuildpathContainer(DLTKCore.java:1982)
at org.eclipse.dltk.internal.launching.InterpreterContainerInitializer.initialize(InterpreterContainerInitializer.java:62)
at org.eclipse.dltk.internal.core.ModelManager.initializeContainer(ModelManager.java:1837)
at org.eclipse.dltk.internal.core.ModelManager.getBuildpathContainer(ModelManager.java:1667)
at org.eclipse.dltk.core.DLTKCore.getBuildpathContainer(DLTKCore.java:1769)
at org.eclipse.dltk.internal.core.ScriptProject.getResolvedBuildpath(ScriptProject.java:459)
at org.eclipse.dltk.internal.core.ScriptProject.getResolvedBuildpath(ScriptProject.java:330)
at org.eclipse.dltk.internal.core.ScriptProject.getAllProjectFragments(ScriptProject.java:3192)
at org.eclipse.dltk.internal.core.ScriptProject.getAllProjectFragments(ScriptProject.java:3185)
at org.eclipse.dltk.core.search.indexing.core.ProjectRequest.run(ProjectRequest.java:67)
at org.eclipse.dltk.core.search.indexing.AbstractJob.execute(AbstractJob.java:76)
at org.eclipse.dltk.internal.core.search.processing.JobManager.run(JobManager.java:467)
at java.lang.Thread.run(Unknown Source)
!ENTRY org.eclipse.core.resources 4 0 2012-09-19 10:48:43.407
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.resources.ResourcesPlugin.stop() of bundle org.eclipse.core.resources.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.stop(BundleContextImpl.java:791)
at org.eclipse.ui.internal.progress.BlockedJobsDialog.createBlockedDialog(BlockedJobsDialog.java:218)
at org.eclipse.ui.internal.dialogs.WorkbenchDialogBlockedHandler.showBlocked(WorkbenchDialogBlockedHandler.java:73)
at org.eclipse.ui.internal.dialogs.WorkbenchDialogBlockedHandler.showBlocked(WorkbenchDialogBlockedHandler.java:87)
at org.eclipse.ui.internal.dialogs.EventLoopProgressMonitor.setBlocked(EventLoopProgressMonitor.java:144)
at org.eclipse.core.internal.jobs.JobManager.reportBlocked(JobManager.java:1032)
at org.eclipse.core.internal.jobs.ThreadJob.waitStart(ThreadJob.java:436)
at org.eclipse.core.internal.jobs.ThreadJob.waitForRun(ThreadJob.java:210)
at org.eclipse.core.internal.jobs.ThreadJob.joinRun(ThreadJob.java:197)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJobs.java:92)
at org.eclipse.core.internal.jobs.JobManager.beginRule(JobManager.java:286)
at org.eclipse.core.internal.resources.WorkManager.checkIn(WorkManager.java:118)
at org.eclipse.core.internal.resources.Workspace.prepareOperation(Workspace.java:2282)
at org.eclipse.core.internal.resources.Workspace.close(Workspace.java:605)
at org.eclipse.core.resources.ResourcesPlugin.stop(ResourcesPlugin.java:415)
... 18 more
Root exception:
!ENTRY org.eclipse.core.jobs 4 2 2012-09-19 10:48:43.478
!MESSAGE An internal error occurred during: "Processing changes since last activation".
!STACK 0
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2350)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2326)
at org.eclipse.dltk.internal.core.ModelManager$4.run(ModelManager.java:1178)
!ENTRY org.eclipse.core.resources 4 566 2012-09-19 10:48:43.479
!MESSAGE Workspace was not properly initialized or has already shutdown.
!ENTRY org.eclipse.core.jobs 4 1 2012-09-19 10:48:43.480
!MESSAGE Worker thread ended job: Processing changes since last activation(21), but still holds rule: ThreadJob(Processing changes since last activation(21),[R/,])
!ENTRY org.eclipse.core.jobs 4 1 2012-09-19 10:48:43.481
!MESSAGE Worker thread ended job: Refreshing workspace(17), but still holds rule: ThreadJob(Refreshing workspace(17),[R/,])
!ENTRY org.eclipse.core.jobs 2 2 2012-09-19 10:48:43.734
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.dltk.internal.ui.InitializeJob
!ENTRY org.eclipse.core.jobs 2 2 2012-09-19 10:48:43.736
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.mylyn.internal.builds.ui.BuildsStartup$1
!ENTRY org.eclipse.core.jobs 2 2 2012-09-19 10:48:43.737
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.progress.ProgressManager$4
somebody can help my?
regards
Attachment: .log
(Size: 892.39KB, Downloaded 62 times)
[Updated on: Wed, 19 September 2012 17:03] Report message to a moderator
FUDForum. Page generated in 0.01590 seconds
