Home » Modeling » Graphiti » Context Pad in graphiti 0.7.3
Context Pad in graphiti 0.7.3 [message #992276] Fri, 21 December 2012 04:02 Go to next message
Marcin Matuszak is currently offline Marcin Matuszak
I have two questions. First: is it possible to use contextPad feature in graphiti 0.7.3? (because I have to work on eclipse 3.5 and newer versions will not work) Is there any documentation how to do this? Because this documentation that I have found refers rather to 0.9 or newer version of graphiti.
Second: If I have a diagram that is constructed with GEF is it possible to add to this diagram only this contextPad feature from graphiti?
Best wishes,
Marcin
Re: Context Pad in graphiti 0.7.3 [message #992386 is a reply to message #992276] Fri, 21 December 2012 09:18 Go to previous messageGo to next message
Michael Wenz is currently offline Michael Wenz
Marcin,
first question: yes the context pad is available in 0.7.3 as well. Basically
the examples for 0.9 should work with 0.7 as well. At least in the area of
the context pad there were only minor modifications. Besides, you could
install a 0.7.3 SDK which contains the tutorial for that version, which
includes a section on how to create the context pad.
Second question: no, that's not possible. The context pad functionality is
closely woven into the Graphiti frmework.
Michael
Re: Context Pad in graphiti 0.7.3 [message #996667 is a reply to message #992386] Wed, 02 January 2013 11:39 Go to previous message
thank you for the answer!
Previous Topic:Digram Editor loses focus on closing of MessageDialog in Graphiti
Next Topic:ResizeFeature: keep aspect Ratio
Current Time: Mon May 20 13:59:19 EDT 2013
Powered by FUDForum. Page generated in 0.07266 seconds
