Home » Eclipse Projects » Subversive » Migration of workspaces from subclipse to subversive
Migration of workspaces from subclipse to subversive [message #524464] Wed, 31 March 2010 23:58 Go to next message
Michael Pellaton is currently offline Michael Pellaton
Hello
We are currently using subclipse with the svnkit backend. However, I
would like to migrate to subversive.
In a workpsace, I noticed that all projects were no longer treated as
being under version control after switching to subversive despite the
fact that svnkit was used by subclipse and subversive (assuming that the
svn metadata should be compatible).
How would a migration of the workspaces look alike? Is there an
alternative to a re-checkout of all projects? I don't mind fiddling in
..project files and alike of it helps...
This is possibly the biggest potential show-stopper for the migration
as ~120 engineers would have to re-checkout all their workspaces.
Michael
Re: Migration of workspaces from subclipse to subversive [message #524492 is a reply to message #524464] Thu, 01 April 2010 03:36 Go to previous messageGo to next message
Igor Burilo is currently offline Igor Burilo
Hello Michael,
Steps to migrate:
1. disconnect all projects (but don't delete SVN meta information)
2. disable Subclipse and restart Eclipse
3. install Subversive
4. select projects and call Team/Share Projects
> Hello
> Thanks
> Michael
Re: Migration of workspaces from subclipse to subversive [message #996640 is a reply to message #524492] Wed, 02 January 2013 10:28 Go to previous message
Malte Kempff is currently offline Malte Kempff
Hi ho,
I got a similar problem. I got Eclipse Juno and have installed subversive on scratch. I am using a workspace that was under subclipse before having those .svn folders. I can see the repositoy with the repository view, but selecting usual Java view I cannot see any grapical hint on the projects that they are already in the repository.
What is ment by the hint "disconnecting all projects"? Is it the context menu order "close project"?
When I then try to "select projects and call Team/Share Projects" Share Projects is mentioned in the Submenu, though, but stays grey and is not selectable Sad
What am I missing?
Previous Topic:How can I improve the Subversive Help?
Next Topic:Where is the subversive repository?
Current Time: Sat May 25 22:36:03 EDT 2013
Powered by FUDForum. Page generated in 0.01601 seconds
