Home » Eclipse Projects » Web Tools Project (WTP) » Conflict for "org.eclipse.wst.sse.ui.format"
Conflict for "org.eclipse.wst.sse.ui.format" [message #218519] Thu, 31 July 2008 12:57 Go to next message
Eclipse User
Originally posted by: gokuiuc.yahoo.com
In Eclipse 3.4 and WTP 3.0, I now get this warning sometimes thrown by the
"org.eclipse.ui.workbench" plugin.
Conflict for
'org.eclipse.wst.sse.ui.format':HandlerActivation(commandId= org.eclipse.wst.sse.ui.format,
handler=org.eclipse.wst.sse.ui.internal.handlers.FormatHandl er,
expression=org.eclipse.core.internal.expressions.ReferenceExpression@d4f4315e,sourcePriority=1073741824)
HandlerActivation(commandId=org.eclipse.wst.sse.ui.format,
expression=org.eclipse.core.internal.expressions.ReferenceExpression@b8a39b5e,sourcePriority=1073741824)
Unfortunately, I cannot determine the cause for this warning. I am using
some extension points from WTP, but none of them involve
"org.eclipse.wst.sse.ui.format".
What can cause this warning?
Gokhan
Re: Conflict for "org.eclipse.wst.sse.ui.format" [message #218526 is a reply to message #218519] Thu, 31 July 2008 14:11 Go to previous messageGo to next message
Nick Sandonato is currently offline Nick Sandonato
Gokhan,
A command is allowed to have zero or more handlers, but only one active
handler. WTP has a few handlers for the command
org.eclipse.wst.sse.ui.format that are based on things like the active
context. It looks like more than one handler may be activated for this
command at the same time.
Nick
Gokhan wrote:
> Hello,
> Conflict for
> Gokhan
Re: Conflict for "org.eclipse.wst.sse.ui.format" [message #996537 is a reply to message #218526] Wed, 02 January 2013 05:12 Go to previous message
Thiago Cardoso de Castro is currently offline Thiago Cardoso de Castro
Hello In order not to create a topic that treat the same subject I'll ask in here. My Eclipse version is Ganymede and I can not upgrade this version to Europe or other like Juno, because of plugins that run only in this version. With this context informed how do I fix this error mentioned in the topic?
Just to confirm that this is the same error log:
Conflict for 'org.eclipse.wst.sse.ui.format':HandlerActivation(commandId=org.eclipse.wst.sse.ui.format,
handler=org.eclipse.wst.sse.ui.internal.handlers.FormatHandler,
expression=org.eclipse.core.internal.expressions.ReferenceExpression@429a8fde,sourcePriority=1073741824)
Previous Topic:WASCE (Geronimo 2.1) DeploymentException error - Cound not open module file
Next Topic:Install JavaScript Development Tools (JSDT)
Current Time: Sat May 25 05:01:04 EDT 2013
Powered by FUDForum. Page generated in 0.11612 seconds
