Home » Eclipse Projects » Remote Application Platform (RAP) » SashForm SWT.SMOOTH
SashForm SWT.SMOOTH [message #991830] Thu, 20 December 2012 04:44 Go to next message
Tiburon T is currently offline Tiburon T
Member
Hello!
I am looking for a way to make a SashForm, that constantly repaints its contents while the sash is moved. I read that the style flag SWT.SMOOTH should trigger this behavior... For me it is not working in RAP and unfortunately I have no way to try it in RCP.
Does the RAP SashForm support SWT.SMOOTH or is there a common workaround like a listener or something?
Re: SashForm SWT.SMOOTH [message #991995 is a reply to message #991830] Thu, 20 December 2012 11:16 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan Furnadjiev
SWT.SMOOTH is a hint and it is not supported by RAP. As layout is
calculated on the server-side supporting SWT.SMOOTH will generate a lot
of network traffic. If you want to be notified when Sash is dragged use
selection listener. The event detail field will contain SWT.DRAG in this
case.
HTH,
Ivan
On 12/20/2012 11:44 AM, Tiburon Mising name wrote:
> Hello!
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: SashForm SWT.SMOOTH [message #996490 is a reply to message #991995] Wed, 02 January 2013 02:50 Go to previous message
Member
thank you for your answer. I'm sure with the listener I can find a solution for our SashForm.
Tiburon
Previous Topic:Branding with RAP 1.5
Next Topic:ClientScripting VerifyListener determine keystroke
Current Time: Sun May 19 01:28:31 EDT 2013
Powered by FUDForum. Page generated in 0.01566 seconds
