Home » Eclipse Projects » scout » Max Fraction Digits stuck at 2
Max Fraction Digits stuck at 2 [message #995051] Fri, 28 December 2012 19:20 Go to next message
Sebastian Boccardi is currently offline Sebastian Boccardi
Member
I have some columns in a table with:
protected int getConfiguredMaxFractionDigits() {
   return 4;
protected int getConfiguredMinFractionDigits() {
   return 4;
But when i try to enter any number with that fraction, like 0.3333 it keeps rounding them up to 2 fraction digits. I tried a Double Column and a BigDecimal column.
Anyone tried this? I'm missing a configuration for that column?
Sebastian
Re: Max Fraction Digits stuck at 2 [message #995495 is a reply to message #995051] Sun, 30 December 2012 03:32 Go to previous messageGo to next message
Adrian Moser
Member
Sebastian, I cannot reproduce this using a simple AbstractDoubleColumn:
        @Order(10.0)
        public class DoubleColumn extends AbstractDoubleColumn {
          protected boolean getConfiguredEditable() {
            return true;
          protected String getConfiguredHeaderText() {
            return TEXTS.get("Company");
            return 4;
            return 4;
Are you using a special format on the column (getConfiguredFormat()/setFormat())?
Adrian
Re: Max Fraction Digits stuck at 2 [message #995556 is a reply to message #995495] Sun, 30 December 2012 08:01 Go to previous messageGo to next message
Member
My column is defined exactly as you entered it. But every time i change the value its rounding to 2 decimals. So the last 2 digits are always 0.
Look at the image attached, after the execCompleteEdit i found something mentioning a 2 fractionDigits for that field.
index.php/fa/12847/0/
  • Attachment: fractions.png
    (Size: 46.91KB, Downloaded 156 times)
Re: Max Fraction Digits stuck at 2 [message #995825 is a reply to message #995556] Mon, 31 December 2012 02:49 Go to previous messageGo to next message
Jeremie Bresson is currently offline Jeremie Bresson
From what I understood in your screenshot, you are using an editable Double Column...
Your problem is that the editingField does not consider the properties of the column (Format, MinFractionDigits, MaxFractionDigits...) when the field is instanciated. You can file a bug for this.
In my opininion the current workarround is to override execPrepareEdit(ITableRow). You can call super.execPrepareEdit(row) cast the IFormField to a IDoubleField and set your properties...
Let me know if you need an example.
I found an other bug with NumberField format and fraction digit: Bug 396979
Re: Max Fraction Digits stuck at 2 [message #995892 is a reply to message #995825] Mon, 31 December 2012 07:32 Go to previous messageGo to next message
Member
Ok, the workarounds works, seems Bug 396979 covers the problem.....
Thanks Jeremie
Re: Max Fraction Digits stuck at 2 [message #995899 is a reply to message #995051] Mon, 31 December 2012 08:04 Go to previous messageGo to next message
Claudio Guglielmo is currently offline Claudio Guglielmo
Member
Hi there
The bug has already been fixed for SR 2, see:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=392425
Claudio
Re: Max Fraction Digits stuck at 2 [message #995939 is a reply to message #995892] Mon, 31 December 2012 10:25 Go to previous messageGo to next message
Bug 396979 is not about "editable double-column properties -> double-field properties". It is just about AbstractNumberField<T> (where T can be a Float) getConfiguredFormat and fraction-digit being set even if the format is set.
I need to review the code modified with 392425 to see if your case "editable double-column properties -> double-field properties" is now covered.
Re: Max Fraction Digits stuck at 2 [message #996542 is a reply to message #995939] Wed, 02 January 2013 05:27 Go to previous messageGo to next message
Jeremie Bresson wrote on Mon, 31 December 2012 16:25
It should be OK.
Re: Max Fraction Digits stuck at 2 [message #997044 is a reply to message #996542] Thu, 03 January 2013 08:33 Go to previous message
Adrian Moser
Member
I did my test on Sun, 30 December 2012 with the latest Eclipse Scout version.
Therefore I can confirm the problem is solved, as Claudio says.
Adrian
Previous Topic:Trouble with images being cached
Next Topic:SVG field external link
Current Time: Fri May 24 00:05:47 EDT 2013
Powered by FUDForum. Page generated in 0.01875 seconds
