| Usage of "org.eclipse.emf.ecore.factory_override" [message #995931] |
Mon, 31 December 2012 09:57  |
Vincenzo Caselli Messages: 42 Registered: January 2012 |
Member |
Hi all,
we are trying to use the "org.eclipse.emf.ecore.factory_override" extension point, but have some problem.
We have 2 plug-ins:
1) Model1: it defines an ecore with entity Variable
2) Model2: defines an ecore with entity CustomVariable that has Model1.Variable as super type
Model2 has also a JUnit class that has the following code:
Variable var = Model1Factory.eINSTANCE.createVariable();
var.setName("a");
System.out.println(var.getClass());
obviously the output is:
class model1.impl.VariableImpl
now, in Model2 plugin, we add the extension
<extension
point="org.eclipse.emf.ecore.factory_override">
<factory
class="org.eclipse.emf.model2.EFactory1"
uri="http://model1/1.0">
</factory>
</extension>
and create the class
public class EFactory1 extends Model1FactoryImpl {
public Variable createVariable() {
return Model2Factory.eINSTANCE.createCustomVariable();
still the object created is
What is the correct way to override the EMF Model1 Factory?
Thank you
and Happy New Year!!!!!
Vincenzo
P.S. I uploaded this sample
| Re: Usage of "org.eclipse.emf.ecore.factory_override" [message #995948 is a reply to message #995931] |
Mon, 31 December 2012 10:58   |
Ed Merks Messages: 24530 Registered: July 2009 |
Vincenco,
Comments below.
On 31/12/2012 3:57 PM, Vincenzo Caselli wrote:
> Hi all,
> We have 2 plug-ins:
No, there shouldn't be two models. Only one, with alternative
implementation classes.
> var.setName("a");
> <extension
> <factory
> </factory>
> </extension>
This has a public constructor?
> @Override
No, the overriding factory should create the proper instances. The
eClass() of what it creates should be the right one from Model1.
> Thank you
> Vincenzo
I'll have a closer look when I have more time, but your use case sounds
not so good...
FUDForum. Page generated in 0.07685 seconds
