Home » Modeling » GMF (Graphical Modeling Framework) » How to get the Model Element of an ILayoutNode?
How to get the Model Element of an ILayoutNode? [message #995924] Mon, 31 December 2012 09:32 Go to next message
Jens Schmidt is currently offline Jens Schmidt
Good day everybody,
i'm creating an editor (obviously) it works all like charm except the layout.
I want to do the layout depending on the Model-Node created with the Factory.
e.g. MetamodellFactory.eINSTANCE.createTankSphericalShape();
More precisely, i have a Map<GMF-Node, Something> and i want to layout depending on the Something in the Map.
So how can i obtain the Model Element from an ILayoutNode (or with)?
Thank you in advance
Jens
Re: How to get the Model Element of an ILayoutNode? [message #997440 is a reply to message #995924] Mon, 07 January 2013 09:27 Go to previous message
Ralph Gerbig is currently offline Ralph Gerbig
there is a method called getNode on ILayoutNode. This returns you the model element in the notation model. You can use this to find the right IGraphicalEdipart in your map.
Ralph
Previous Topic:How to register Connection Edit Part as Drop Target
Next Topic:How to Set Default Grid line style, line color, and "on top"
Current Time: Tue May 21 16:24:58 EDT 2013
Powered by FUDForum. Page generated in 0.01839 seconds
