| Problem loading XSD file [message #995921] |
Mon, 31 December 2012 09:25 |
Max Bureck Messages: 9 Registered: January 2012 |
Junior Member |
I tried to load a modified version of a MathML 3.0 schema (just including the presentation elements) as an EMF meta model, but loading of the XSD file fails with the following message:
'no duplicates' constraint is violated
The same message is shown when I try to load the file using the Sample Reflective Ecore Model Editor. The XSD editor, however, does not show an error, so I have no clue what should be wrong. I attached the schema files, so if someone of the XSD team could have a look at it, I would be more more than happy
Thank you very much,
Max
FUDForum. Page generated in 0.01603 seconds
