Home » Modeling » QVT-OML » Wrong execution order in inheriting mapping operations?
| Wrong execution order in inheriting mapping operations? [message #991534] |
Wed, 19 December 2012 12:14  |
Dietrich Travkin Messages: 11 Registered: July 2009 |
Junior Member |
I'm using some mapping operations that inherit from another mapping operation. The abstract mapping operation defines init and end phases/sections, but these are executed after the population phase of the inheriting mapping operations. Is that a bug or is this the desired behavior? I think, this is a bug.
Here is an example:
abstract mapping DesignElement::designElement2EModelElement() : EModelElement
init
// do something
result := ...
end
// do something
mapping Type::type2EcoreElements() : EClass
inherits DesignElement::designElement2EModelElement
name := self.name;
// do something more
When executing the type2EcoreElements mapping operation, the name attribute is set before the init section of the designElement2EModelElement mapping operation is executed. Thus, the assignement "result := ..." results in a thrown exception, since the result object is already created when the assignment is executed.
I think, the init section of designElement2EModelElement has to be executed before the population phase of type2EcoreElements begins.
Another problems is that the order of execution is beginning with the most special mapping operation. I think it has to be the other way around so that specialized operations can reuse results of previously executed inherited operations.
Am I wrong?
Dietrich
| Re: Wrong execution order in inheriting mapping operations? [message #996347 is a reply to message #991534] |
Tue, 01 January 2013 16:33   |
Christopher Gerking Messages: 33 Registered: April 2011 |
Member |
Hi Dietrich,
are you sure that QVTo actually executes the population section first? That should not be the case. According to the spec, the correct behavior would be the following:
- Execute the so called "implicit instantiation section" (spec p. 93) of type2EcoreElements(), which creates an instance of EClass as result.
- Execute the init section of the inherited mapping designElement2EModelElement(), which creates another return value, which should override the previously created EClass.
- Execute the end section of designElement2EModelElement().
- Execute the population section of type2EcoreElements(), which sets the 'name' attribute of the result.
Hence, your scenario is special since you create multiple result values. I tried to reproduce the problem, but there is no exception in my case. However, the problem seems to be that the 'name' attribute is never set effectively. I suppose this is caused by a problem with the second result value failing to override the initial EClass result correctly. This could be related to the following bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=388325, which is currently about to be fixed.
Could the exception be caused by the actual value that is assigned to the result? What is the type of the assigned value? If it is not a subtype of EClass, a runtime exception is unavoidable.
Quote:Another problems is that the order of execution is beginning with the most special mapping operation. I think it has to be the other way around so that specialized operations can reuse results of previously executed inherited operations. Talking about the "order of execution", we must distinguish the different sections:
with respect to the population section, QVTo actually begins with the most general inherited mapping. With respect to the "implicit instantiation section", it must start with the most special mapping, because an inherited mapping might not know which concrete type it should instantiate as result. Only the most specific mapping is guaranteed to refer to the concrete type, hence the instantiation must begin there. With respect to the init section, I agree that a different order might be a better solution than the one currently described in the spec.
| Re: Wrong execution order in inheriting mapping operations? [message #996532 is a reply to message #996347] |
Wed, 02 January 2013 05:03   |
Ed Willink Messages: 3185 Registered: July 2009 |
It seems that the semantics need to be sorted out here.
I take the view, not specified, that a transformation language should do
as much as possible and that a smart implementation may eliminate the
associated redundancy. Thus all actions at all levels of
inheritance/refinement should occur. The created object has only one
actual concrete type so all inherited actions should respect this type.
In principle this could be achieved by some rewrite rules that defined
the appropriate creation of a flat construction for the one and only
concrete type. Once viewed as a flat construction, most-derived actions
first seems obvious. Local variables are permitted.
Overridden initialization may be eliminated if the redundant
initialization is side-effect free.
In order to modularize construction and re-use inherited support in a
practical implementation, it may be necessary to pass the concrete type
to the inherited constructors. Since QVTo is interpreted, synthesizing
the flat construction may be easier.
Christopher: would you like to take a shot at a clear exposition of the
semantics so that we can see whether Mariano Belaunde thinks it is sensible?
Ed Willink
On 01/01/2013 21:34, Christopher G. wrote:
> Hi Dietrich,
> Quote:
> different sections:
| Re: Wrong execution order in inheriting mapping operations? [message #996722 is a reply to message #996532] |
Wed, 02 January 2013 14:14   |
Fabio L. S. Messages: 15 Registered: July 2010 Location: Brazil |
Junior Member |
Sorry for my wrong answer. My discomfort with the mapping inheritance semantics made me read what I wanted to read... Christopher is right about how the code posted should work.
Anyhow, the problem with the "execution order" is that all the parent (inherited) mapping is completely executed after the init and implicit instantiation section of the inheriting mapping. Thus, not only the order of init section is strange. The populate section, end section, when clause, and where clause have a strange order. What may be even more confusing, when the "when" section of the parent mapping does not hold, the Eclipse QVTo does not execute the parent mapping but continues normally with the execution of the inheriting mapping. I think this is absurdly wrong, but the OMG specification does not explain what should be done in this situation. Therefore, the Eclipse QVTo implementation is not incorrect.
I know it is not the correct place to discuss the problems in the OMG specification. As Ed suggested, I will raise an issue on OMG.
Again, sorry for my wrong answer.
Regards;
Fabio Levy Siqueira
| Re: Wrong execution order in inheriting mapping operations? [message #997423 is a reply to message #996722] |
Mon, 07 January 2013 08:09   |
Junior Member |
Hello all,
thank you for your helpful feedback.
Indeed, the execution order in the QVTo specification in some cases is quite confusing, which has to be reported to the OMG.
With Christopher's hints, I think, I understand the behavior in my special case better. I used the debugger to step through my transformation. The execution begins with the most special mapping operation (which is correct according to the spec., pages 77,78 PDF-pages 93,94). In my case, the transformation is more complex than the example above: I have another operation inheriting from type2EcoreElements() whose implicit instantiation section seems to be executed to create an EClass. After that the init section of the operation designElement2EModelElement() is executed which sets the result variable to an already existing EClass (I have an in-place transformation with an inout parameter). Since I don't know the concrete type of the result object in this abstract operation (in other inheriting operations it is another type than EClass), I don't cast the result object to EClass before assigning it to the result variable, thus, it is only known to be an EModelElement, but should be assignable to the result variable, since the result type of my designElement2EModelElement() is declared to be EModelElement which is a supertype of EClass. Though, the assignment result := <the already existing EClass object> or the implicit instantiation section of the operation designElement2EModelElement() leads to a QVTo runtime exception "Cannot instantiate type EModelElement". Thus, as Christopher reported, the exception could be raised due to the failure of overriding the initially created result (the EClass object created in the implicit instantiation section of type2EcoreElements()) in the init section of designElement2EModelElement().
However, I'm working on another solution to my problem and avoided the described situation be restructuring my transformation.
Dietrich
Current Time: Sat May 25 20:43:52 EDT 2013
Powered by FUDForum. Page generated in 0.09466 seconds
