Home » Eclipse Projects » BIRT » Yearly/Quarterly Report in Crosstab(Yearly/Quarterly Report in Crosstab)
Re: Yearly/Quarterly Report in Crosstab [message #993026 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Michael Williams is currently offline Michael Williams
Member
Create computed columns to create your groupings, rather than using the auto groupings. That should allow you to do what you're wanting. Let me know your BIRT version, if you need an example.
Michael Williams
http://www.birt-exchange.org
Re: Yearly/Quarterly Report in Crosstab [message #993028 is a reply to message #992961] Sun, 23 December 2012 01:08 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993029 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993030 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993031 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993033 is a reply to message #992961] Sun, 23 December 2012 01:08 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993034 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993035 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993036 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993038 is a reply to message #992961] Sun, 23 December 2012 01:08 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993039 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993040 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993041 is a reply to message #992961] Sun, 23 December 2012 01:09 Go to previous messageGo to next message
Member
Michael Williams
Re: Yearly/Quarterly Report in Crosstab [message #993176 is a reply to message #992977] Sun, 23 December 2012 11:58 Go to previous messageGo to next message
dhruba kumar is currently offline dhruba kumar
Member
hi ,
Iam using BIRT 4.2.1.
Please give an example
Re: Yearly/Quarterly Report in Crosstab [message #993182 is a reply to message #993176] Sun, 23 December 2012 12:16 Go to previous messageGo to next message
Member
hi ,
Re: Yearly/Quarterly Report in Crosstab [message #993262 is a reply to message #993182] Sun, 23 December 2012 17:49 Go to previous messageGo to next message
Wow. Not sure what happened there.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Yearly/Quarterly Report in Crosstab [message #993331 is a reply to message #993262] Sun, 23 December 2012 23:14 Go to previous messageGo to next message
Member
Hi please give an example of computed column of any birt version.In your previous reply you asked me for BIRT version for example
Re: Yearly/Quarterly Report in Crosstab [message #994864 is a reply to message #993331] Fri, 28 December 2012 08:50 Go to previous messageGo to next message
Sorry for the delay. I was off for the holiday. I'll get an example made, right now.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Re: Yearly/Quarterly Report in Crosstab [message #994872 is a reply to message #992961] Fri, 28 December 2012 09:15 Go to previous message
Take a look at this report design. There are two computed columns in the dataSet to create the new cube groups with. The top crosstab shows the original setup with the default groups. The second one shows what it looks like using the computed fields.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:Adding an object to the application context! (Book example: Integrating and Extending)
Next Topic:making birtviewer 3.7.1 compatible for IE9
Current Time: Sat May 25 08:06:06 EDT 2013
Powered by FUDForum. Page generated in 0.02874 seconds
