Home » Modeling » EMF » [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl
[CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #990476] Wed, 12 December 2012 11:12 Go to next message
Stephan Krusche is currently offline Stephan Krusche
I am using CDO 4.2 (I20121206-0553) with the HibernateStore Configuration with EMF 2.9.0-M3, Teneo 2.0.1, Hibernate 4.1.1 and Eclipse 4.3-M3.
When I create new objects in my CDO Client, add them to a resource (in my empty database) and commit them, everything works fine.
I can also change values of these attributes and commit these changes without problems.
However creating new objects sometimes leads to the following Hibernate MappingException on the CDO HibernateStore:
org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl
	at org.hibernate.internal.SessionFactoryImpl.getEntityPersister(SessionFactoryImpl.java:1190)
	at org.hibernate.type.EntityType.toLoggableString(EntityType.java:494)
	at org.hibernate.type.AnyType.toLoggableString(AnyType.java:201)
	at org.hibernate.type.CollectionType.renderLoggableString(CollectionType.java:193)
	at org.hibernate.type.CollectionType.toLoggableString(CollectionType.java:184)
	at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:79)
	at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:121)
	at org.hibernate.event.internal.AbstractFlushingEventListener.logFlushResults(AbstractFlushingEventListener.java:131)
	at org.hibernate.event.internal.AbstractFlushingEventListener.flushEverythingToExecutions(AbstractFlushingEventListener.java:107)
	at org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51)
	at org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1127)
	at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:952)
	at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:151)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:531)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:46)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
	at org.eclipse.emf.cdo.internal.server.Repository.commitUnsynced(Repository.java:917)
	at org.eclipse.emf.cdo.internal.server.Repository.commit(Repository.java:910)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:295)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:97)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:680)
On CDO Client side I get the following exception:
[ERROR] Rollback in HibernateStore: org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl
Does anyone have an idea why I get this exception and how can I avoid it?
Thanks for help
Stephan
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #990499 is a reply to message #990476] Wed, 12 December 2012 13:39 Go to previous messageGo to next message
Erdal Karaca is currently offline Erdal Karaca
I think I encountered that stack trace already: you could try to use a less verbose log setting until Martin comes with a better solution Smile
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #990702 is a reply to message #990499] Wed, 12 December 2012 17:05 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hmm, yes it seems related to the log setting, can you tell me what log4j or other log settings you use?
Maybe I can reproduce it and solve it more thoroughly..
gr. Martin
> a better solution :)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #991190 is a reply to message #990702] Mon, 17 December 2012 11:39 Go to previous messageGo to next message
Hi Martin,
I am not injecting specific log settings for the CDO server and thus not using anything specific. However on my target platform log4j is existing and I have my own log4j Logger. I subclass org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication in order to set some SSL settings:
public class CDOApplication extends CDOServerApplication {
	public CDOApplication() {
		super();
		prepareSSLCommunication();
		registerEPackages();
	private void registerEPackages() {
		for(EPackage ePkg : PackageUtil.allPackages) {
			EPackage.Registry.INSTANCE.put(ePkg.getNsURI(), ePkg);
	private void prepareSSLCommunication() {
		// Prepare SSL communication
		Authentication authentication = Authentication.getInstance();
		File keyFile = new File(authentication.getPathToKeyStore());
		String keyURLPath = null;
		try {
			keyURLPath = keyFile.toURI().toURL().toString();
		} catch (MalformedURLException ex) {
			Logger.error(ex);
		SSLUtil.setDefaultSSLConfiguration(keyURLPath, keyURLPath, authentication.getKeyStorePassword());
At the moment I see the following log when starting the CDO server with an empty database:
[INFO] CDO server starting
!SESSION 2012-12-17 17:29:22.834 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_37
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=cocoa, NL=en_US
Framework arguments:  -product de.tum.in.www1.armed.cdo.server.product
Command-line arguments:  -product de.tum.in.www1.armed.cdo.server.product -data /Users/krusche/Development/armed-kepler-m3/workspace/../runtime/cdo-server.product -dev file:/Users/krusche/Development/armed-kepler-m3/workspace/.metadata/.plugins/org.eclipse.pde.core/cdo-server.product/dev.properties -os macosx -ws cocoa -arch x86 -consoleLog
!ENTRY org.eclipse.emf.cdo.server 1 0 2012-12-17 17:29:24.694
!MESSAGE CDO server starting
log4j: Trying to find [log4j.xml] using context classloader org.eclipse.core.runtime.internal.adaptor.ContextFinder@a826da.
log4j: Trying to find [log4j.xml] using org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@1cbda0a[org.apache.log4j:1.2.16(id=66)] class loader.
log4j: Trying to find [log4j.xml] using ClassLoader.getSystemResource().
log4j: Trying to find [log4j.properties] using context classloader org.eclipse.core.runtime.internal.adaptor.ContextFinder@a826da.
log4j: Trying to find [log4j.properties] using org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@1cbda0a[org.apache.log4j:1.2.16(id=66)] class loader.
log4j: Trying to find [log4j.properties] using ClassLoader.getSystemResource().
log4j: Could not find resource: [null].
log4j:WARN No appenders could be found for logger (org.jboss.logging).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for more info.
    create table cdo_package_info (
        packageURI varchar(255) not null,
        parentURI varchar(255),
        cdo_package_unit_id varchar(255),
        idx integer,
        primary key (packageURI)
    ) ENGINE=InnoDB
    create table cdo_package_unit (
        nsUri varchar(255) not null,
        originalType tinyblob,
        timeStamp bigint,
        EPackageBlob longblob,
        primary key (nsUri)
    ) ENGINE=InnoDB
    create table cdo_system_information (
        id integer not null auto_increment,
        creationTime bigint,
        primary key (id)
    ) ENGINE=InnoDB
    create table cdo_system_property (
        name varchar(255) not null,
        value longtext,
        primary key (name)
    ) ENGINE=InnoDB
    alter table cdo_package_info
        add index FK5702C978798F06A8 (cdo_package_unit_id),
        add constraint FK5702C978798F06A8
        foreign key (cdo_package_unit_id)
        references cdo_package_unit (nsUri)
Dec 17, 2012 5:29:26 PM org.eclipse.emf.teneo.classloader.ClassLoaderResolver setClassLoaderStrategy
INFO: Class loader strategy set to: org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
Dec 17, 2012 5:29:27 PM org.eclipse.emf.teneo.hibernate.HbDataStore setDefaultProperties
INFO: Hibernate property: hibernate.hbm2ddl.auto not set, setting to update
Dec 17, 2012 5:29:27 PM org.eclipse.emf.teneo.hibernate.HbDataStore logProperties
INFO: hibernate.connection.url: jdbc:mysql://localhost:3306/armed?createDatabaseIfNotExist=true
INFO: teneo.mapping.default_varchar_length: -1
INFO: teneo.mapping.set_default_cascade_on_non_containment:
INFO: teneo.naming.default_id_feature: e_id
INFO: teneo.naming.auditing.jointable.postfix: Auditing
INFO: teneo.mapping.auditing.prune.commit.interval: 1000
INFO: teneo.mapping.cascade_policy_on_non_containment: PERSIST,MERGE
INFO: teneo.mapping.always_version: true
INFO: hibernate.cache.provider_class: org.hibernate.cache.HashtableCacheProvider
INFO: e_container_column: e_container
INFO: teneo.mapping.fetch_one_to_many_extra_lazy: false
INFO: teneo.naming.sql_discriminator_version_immutable_eclass: true
INFO: teneo.runtime.update_schema: false
INFO: teneo.runtime.handle_unset_as_null: true
INFO: teneo.naming.version_column: e_version
INFO: teneo.mapping.set_proxy: false
INFO: teneo.naming.discriminator_column_name: DTYPE
INFO: teneo.mapping.auditing.enable: false
INFO: teneo.mapping.disable_econtainer: false
INFO: teneo.naming.sql_column_name_prefix:
INFO: teneo.naming.auto_adapt_manual_set_sql_names: true
INFO: teneo.mapping.set_entity_automatically: true
INFO: teneo.naming.join_column_naming_strategy: unique
INFO: teneo.naming.set_foreign_key_name: true
INFO: teneo.naming.set_generated_value_on_id_feature: true
INFO: teneo.mapping.auditing.prune.days: 0
INFO: teneo.mapping.emap_as_true_map: true
INFO: teneo.mapping.inheritance: SINGLE_TABLE
INFO: teneo.naming.id_feature_as_primary_key: true
INFO: hibernate.max_fetch_depth: 3
INFO: e_container_feature_name_column: e_container_feature_name
INFO: hibernate.connection.password: deadbeef
INFO: teneo.mapping.UserTimeType: org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
INFO: teneo.mapping.UserDateTimeType: org.eclipse.emf.teneo.hibernate.mapping.XSDDateTime
INFO: teneo.mapping.hibernate_mapping_file: false
INFO: teneo.mapping.UserDateType: org.eclipse.emf.teneo.hibernate.mapping.XSDDate
INFO: teneo.mapping.add_index_for_fk: true
INFO: teneo.mapping.map_all_lists_as_idbag: false
INFO: hibernate.connection.username: root
INFO: teneo.naming.idbag_id_column_name: ID
INFO: teneo.mapping.ignore_eannotations: false
INFO: teneo.naming.econtainer_feature_persistence_strategy: FEATURENAME
INFO: teneo.naming.strategy: lowercase
INFO: teneo.naming.join_table_naming_strategy: unique
INFO: hibernate.hbm2ddl.auto: update
INFO: teneo.mapping.XSDDateClass: javax.xml.datatype.XMLGregorianCalendar
INFO: teneo.naming.sql_index_name_prefix:
INFO: teneo.mapping.extra_annotation_sources:
INFO: hibernate.connection.driver_class: com.mysql.jdbc.Driver
INFO: teneo.naming.sql_fk_name_prefix:
INFO: hibernate.dialect: org.hibernate.dialect.MySQL5InnoDBDialect
INFO: teneo.mapping.map_document_root: false
INFO: teneo.mapping.max_comment_length: 0
INFO: teneo.naming.max_sql_name_length: -1
INFO: teneo.naming.default_id_column: e_id
INFO: teneo.mapping.always_map_list_as_bag: false
INFO: teneo.mapping.force_lazy: false
INFO: teneo.mapping.also_map_as_class: true
INFO: teneo.mapping.default_temporal: TIMESTAMP
INFO: teneo.naming.auditing.entity.prefix:
INFO: econtainer_class_column: econtainer_class
INFO: teneo.mapping.persistence_xml.parse.lenient: false
INFO: teneo.mapping.fetch_containment_eagerly: false
INFO: teneo.mapping.map_embeddable_as_embedded: false
INFO: teneo.mapping.sql_name_escape_character: `
INFO: teneo.mapping.eav_mapping: false
INFO: teneo.mapping.optimistic_locking: true
INFO: teneo.mapping.cascade_all_on_containment:
INFO: teneo.naming.sql_table_name_prefix:
INFO: teneo.runtime.convert_unset_to_null: false
INFO: teneo.mapping.cascade_policy_on_containment: ALL
INFO: teneo.mapping.default_cache_strategy: NONE
INFO: teneo.mapping.auditing.database.schema:
INFO: teneo.mapping.featuremap_as_component: false
INFO: teneo.naming.auditing.entity.postfix: Auditing
INFO: teneo.mapping.join_table_for_non_contained_associations: true
INFO: teneo.mapping.auto_add_referenced_epackages: false
INFO: hibernate.connection.pool_size: 10
[INFO] Net4j extension starting
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2012-12-17 17:29:27.486
!MESSAGE Net4j extension starting
[INFO] Net4j extension started
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2012-12-17 17:29:27.539
!MESSAGE Net4j extension started
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2012-12-17 17:29:27.539
!MESSAGE CDO server started
Further investigations showed that always the first commit (independent which objects) works and that always the second commit fails.
Any idea why this happens?
Thanks for help and best regards
Stephan
Martin taal wrote on Wed, 12 December 2012 17:05
gr. Martin
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #991670 is a reply to message #990476] Wed, 19 December 2012 19:25 Go to previous messageGo to next message
any ideas what the problem could be?
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #991889 is a reply to message #991670] Thu, 20 December 2012 07:26 Go to previous messageGo to next message
Hi Stephan,
Sorry missed it, it seems to be a bug in hibernate that it does not support logging using entities which are mapped with
only entity names:
Somehwere in the code this method is called to get the Entity Type, it uses the class name instead of the entity name.
public static Type entity(Class persistentClass) {
return entity( persistentClass.getName() );
It should use the entity name instead. I think this is a hibernate bug. Can you check in the hibernate site/forum to see
if it is solved? Or post it there as a question.
gr. Martin
The Netherlands
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #992388 is a reply to message #991889] Fri, 21 December 2012 09:25 Go to previous messageGo to next message
Can I not just deactivate logging in order to solve the problem?
If yes, how can you deactivate it?
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #992397 is a reply to message #992388] Fri, 21 December 2012 09:39 Go to previous messageGo to next message
Hi Stephan,
Here is some information:
http://wiki.eclipse.org/CDO/Hibernate_Store/Configuration_and_Setup#How_to_enable_Hibernate_logging
http://www.eclipsezone.com/eclipse/forums/t99588.html
Attached an example log4j.properties I use.
If you can solve this by using a different log setting, can you let me know what you did? So I can update the wiki.
gr. Martin
The Netherlands
# Set root logger level to error and its only appender to A1.
log4j.rootCategory=error, A1
log4j.category.JPOX=OFF
# A1 is set to be a ConsoleAppender.
log4j.appender.A1=org.apache.log4j.ConsoleAppender
# A1 uses PatternLayout.
log4j.appender.A1.layout=org.apache.log4j.PatternLayout
log4j.appender.A1.layout.ConversionPattern=%-4r [%t] %-5p %c %x - %m%n
#log4j.logger.org.hibernate=error
#org.hibernate.pretty
### log HQL query parser activity
log4j.logger.org.hibernate.hql.ast.AST=error
### log just the SQL
log4j.logger.org.hibernate.SQL=debug
### log JDBC bind parameters ###
log4j.logger.org.hibernate.type=error
#log4j.logger.org.hibernate.type=error
### log schema export/update ###
log4j.logger.org.hibernate.tool.hbm2ddl=error
### log HQL parse trees
log4j.logger.org.hibernate.hql=error
### log cache activity ###
log4j.logger.org.hibernate.cache=error
### log transaction activity
log4j.logger.org.hibernate.transaction=error
### log JDBC resource acquisition
log4j.logger.org.hibernate.jdbc=error
### enable the following line if you want to track down connection ###
### leakages when using DriverManagerConnectionProvider ###
log4j.logger.org.hibernate.connection.DriverManagerConnectionProvider=error
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #992401 is a reply to message #992388] Fri, 21 December 2012 09:39 Go to previous messageGo to next message
Hi Stephan,
gr. Martin
The Netherlands
Re: [CDO] HibernateStore MappingException: Unknown entity: CDORevisionImpl [message #994648 is a reply to message #992401] Thu, 27 December 2012 18:16 Go to previous message
Hi Martin,
with your log settings I can avoid this error.
Thanks for the tip.
Best regards
Stephan
Previous Topic:[CDO] Skipping EClasses/EStructuralFeatures from prefetch
Next Topic:Xcore persistence format
Current Time: Tue May 21 20:44:14 EDT 2013
Powered by FUDForum. Page generated in 0.02062 seconds
