Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Eclipse Juno Reporting(Unhandled event loop exception No more handles [Could not detect registered XULRunner to use])
Eclipse Juno Reporting [message #986589] Wed, 21 November 2012 00:47 Go to next message
rim sh
While previewing the report in Eclipse Juno getting the below error
Using Ubuntu 12.04
"Unhandled event loop exception
No more handles [Could not detect registered XULRunner to use]"
Need help on this!!
Re: Eclipse Juno Reporting [message #994502 is a reply to message #986589] Thu, 27 December 2012 09:04 Go to previous messageGo to next message
bernard morrin is currently offline bernard morrin
I have the same problem, I find a temporary solution.
You can try:
In console: eclipse -vmargs -Dorg.eclipse.swt.browser.DefaultType=mozilla
Or in eclipse.ini -Dorg.eclipse.swt.browser.DefaultType=mozilla (or chrome )
You must check in "preference->report design-> preview" : Always use external browsers.
Bye
Re: Eclipse Juno Reporting [message #1014969 is a reply to message #994502] Tue, 26 February 2013 21:03 Go to previous messageGo to next message
Stella Lok is currently offline Stella Lok
I encountered this error before when using XULRunner. Putting this in eclipse.ini works for me: -Dorg.eclipse.swt.browser.XULRunnerPath=<xulrunner-directory-path>
[Updated on: Tue, 26 February 2013 21:05]
Report message to a moderator
Re: Eclipse Juno Reporting [message #1015455 is a reply to message #986589] Thu, 28 February 2013 10:56 Go to previous message
Grant Gayed is currently offline Grant Gayed
If there's an app/plugin that is creating a Browser with style
SWT.MOZILLA then it should be shipping a XULRunner and explicitly
pointing at it, in addition to setting the
org.eclipse.swt.browser.DefaultType property as described in
http://www.eclipse.org/swt/faq.php#browserspecifydefault . It cannot be
assumed that a usable XULRunner will be auto-detected on any OS anymore,
including Linux.
Grant
> Using Ubuntu 12.04
> Need help on this!!
Previous Topic:Problem with copying and pasting in XULRunner Browser on Eclipse
Next Topic:Create a rectangle of selection
Current Time: Fri May 24 16:29:18 EDT 2013
Powered by FUDForum. Page generated in 0.05013 seconds
