Home » Eclipse Projects » Eclipse 4 » NoClassDefFound - jexel
NoClassDefFound - jexel [message #993210] Sun, 23 December 2012 14:15 Go to next message
Aljoscha Steffens is currently offline Aljoscha Steffens
I try to get this tutorial http://www.vogella.com/articles/JavaExcel/article.html to work but I get the NoClassDefFoundError
!SESSION 2012-12-23 20:08:34.796 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_09
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments:  -product MEXA.product
Command-line arguments:  -product MEXA.product -data D:\eclipse\Workspace/../runtime-MEXA.product -dev file:D:/eclipse/Workspace/.metadata/.plugins/org.eclipse.pde.core/MEXA.product/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench 4 0 2012-12-23 20:08:39.208
!MESSAGE Internal Error
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: jxl/read/biff/BiffException
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
	at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NoClassDefFoundError: jxl/read/biff/BiffException
	at MEXA.handlers.CreateSampleProject.execute(CreateSampleProject.java:40)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	... 30 more
Caused by: java.lang.ClassNotFoundException: jxl.read.biff.BiffException
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	... 36 more
The thing is, this does NOT happen, if I wirte the Read-Method in a main function.
I have an appliation project and if I create a class with main method (in which I paste the read funktion of the tutorial) it's alright, if I change the methods name it doesn't. How can that be?
Do I have to specify some dependencies somewhere? To use jexel I just copied the required files into my Project and set the Buildpath accordingly.
[Updated on: Sun, 23 December 2012 14:16]
Report message to a moderator
Re: NoClassDefFound - jexel [message #993440 is a reply to message #993210] Mon, 24 December 2012 06:51 Go to previous messageGo to next message
Sopot Cela is currently offline Sopot Cela
If you use a normal java app the build path is the right thing to edit but in an RCP (OSGi) app your jars go into manifest dependencies and .product. This manifest and product expect an osgi bundle jar. To convert a normal jar into an osgi bundle jar use New->Plug-in from existing jar. Then add the created plugin in manifest and .product.
Re: NoClassDefFound - jexel [message #994471 is a reply to message #993440] Thu, 27 December 2012 06:56 Go to previous message
Thanks this works perfect!
Previous Topic:Hello world in eclipse 4
Next Topic:Splash Screen with Progress Bar and Messages
Current Time: Sat May 25 07:14:40 EDT 2013
Powered by FUDForum. Page generated in 0.03251 seconds
