| still report "Test Data for this node is incomplete" even an external excel file is provid [message #993361] |
Mon, 24 December 2012 01:38  |
Yolanda Zheng Messages: 2 Registered: December 2012 |
Junior Member |
I have a test case named "Check Mask Design Setting". It has variables name, alias, layer, datatype, scale, source, x_offset, y_offset, rotation and mirror. For the case, i didn't provide any data input.
Then i created another test case named "01-02-001-1-addLayer", in which the test case "Check Mask Design Setting" is reused. And I uploaded an external excel file as data input to the case "Check Mask Design Setting". But jubula still had a cross on the case, indicating that test data for this node is incomplete.
Seems jubula didn't recognize my input data. Because i didn't see an excel marker on the right bottom of test case. Does anybody have similar issue and have workaround or solution for it? Thanks.
Attachment: error.png
(Size: 29.54KB, Downloaded 91 times)
FUDForum. Page generated in 0.01784 seconds
