Home » Newcomers » Newcomers » Installing EGit in Helios w/PHP development env(missing resource(s))
Installing EGit in Helios w/PHP development env [message #994229] Wed, 26 December 2012 14:45 Go to next message
Roy Epperson is currently offline Roy Epperson
I'm trying to install EGit into Helios w/ the PHP environment on Ubuntu and getting the following:
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse EGit 2.2.0.201212191850-r (org.eclipse.egit.feature.group 2.2.0.201212191850-r)
Missing requirement: Git Team Provider UI 2.2.0.201212191850-r (org.eclipse.egit.ui 2.2.0.201212191850-r) requires 'bundle org.eclipse.core.runtime [3.7.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: Eclipse EGit 2.2.0.201212191850-r (org.eclipse.egit.feature.group 2.2.0.201212191850-r)
To: org.eclipse.egit.ui [2.2.0.201212191850-r]
Searches of the forums is not helping.....
TIA,
Roy
Re: Installing EGit in Helios w/PHP development env [message #994496 is a reply to message #994229] Thu, 27 December 2012 08:39 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Looks like Helios is no longer supported. The version numbers indicated relate to Indigo.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:adding gtk-library, c++
Next Topic:After doing check for updates, eclipse no longer loads
Current Time: Wed May 22 05:43:58 EDT 2013
Powered by FUDForum. Page generated in 0.01603 seconds
