Home » Newcomers » Newcomers » Egit error upon install of Eclipse(Cannot set Egit to locate git in my system to use Eclipse )
icon5.gif  Egit error upon install of Eclipse [message #993957] Tue, 25 December 2012 20:54 Go to next message
Zachariah Lloyd is currently offline Zachariah Lloyd
I downloaded and installed Eclipse IDE for Java Developers version 1.5.1.20120920-0737, but when I open it I get this error every time,
"EGit does not require Git to function, but there may be important settings in the installation directory the EGit needs to know in order to be compatible with Git."?? There is some more written after this, but that is the crux of what is wrong....
I have tried going to a new project, and selecting Team>Share Project>Git, but what opens up I do not understand truthfully, I am completely new to Eclipse and know nothing yet really. Embarrassed
I click Create, and enter a repository folder name, but I am not sure if I am supposed to put anything in the field that asks for Path within Repository or not?? Confused
Any advice would be greatly appreciated and thanks in advance!! Surprised
Zachariah A Lloyd
Re: Egit error upon install of Eclipse [message #994065 is a reply to message #993957] Wed, 26 December 2012 04:45 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Better to ask on the eclipse.egit forum. You're no doubt best off to
install the command line version of git so you have a fallback if
there's something you can't do in the IDE.
> completely new to Eclipse and know nothing yet really. :blush: I click
> Repository or not?? :? Any advice would be greatly appreciated and
> thanks in advance!! :o
Re: Egit error upon install of Eclipse [message #994179 is a reply to message #994065] Wed, 26 December 2012 11:24 Go to previous message
David Wegener is currently offline David Wegener
This isn't an error, it is a notification message telling you that if you use git, there may be settings that the egit implementation in Eclipse interprets differently then a native git install on your system. If you don't have git installed and don't want to use git, you can ignore the message. If you use git, then you should check that the egit repository settings match what you expect on your system. I believe the settings in question regard line endings and possibly file encodings.
Previous Topic:keywords pop-upz
Next Topic:Emulsifier
Current Time: Sat May 18 19:16:10 EDT 2013
Powered by FUDForum. Page generated in 0.01509 seconds
