| Eclipse don't want to compile [message #992061] |
Thu, 20 December 2012 14:28  |
Daniele Vergara Messages: 1 Registered: December 2012 |
Junior Member |
Hey guys,
I've just installed Eclipse Indigo 3.7.2 on my PC with Windows 8, but it don't want to compile. I also installed CDT 8.0.2.
When i try to compile my file AccountTest.cpp it gets me this error:
**** Rebuild of configuration Debug for project Homework1 ****
**** Internal Builder is used for build ****
cl /c /EHs /MD /Zi /nologo /FoAccountTest.obj ..\AccountTest.cpp
Internal Builder: Cannot run program "cl": Launching failed
Error: Program "cl" is not found in PATH
PATH=[C:/Program Files/Java/jre7/bin/client;C:/Program Files/Java/jre7/bin;C:/Program Files/Java/jre7/lib/i386;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\MinGw\lib;c:\MinGw\bin;;C:\eclipse;]
Build error occurred, build is stopped
Time consumed: 139 ms.
I've already set the environment variable "Path", adding a semicolon and typing "C:\MinGw\lib;c:\MinGw\bin;".
I'm using, as you can see, a MinGW C++ compiler.
Eclipse gives me also an error when I include whatever library. For example, when I include <iostream> it says to me "Unresolved inclusion" and so Eclipse cannot resolve any cout or cin operation. I'm sure that this depends by this error.
Can you help me?
Thank you.
FUDForum. Page generated in 0.07597 seconds
