| Generate Java code from a Java model [message #776997] |
Mon, 09 January 2012 11:23  |
Marcus Fessele Messages: 4 Registered: January 2012 |
Junior Member |
Hey guys,
I want to generate java code from a .xmi model. I extracted the model from a project and now I want to generate code refers to ttp://wiki.eclipse.org/MoDisco/Components/Java/Documentation/0.9#Java_Generation
But when I write the sample code I get an error:
"The type org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator cannot be resolved. It is indirectly referenced from required .class files"
My code:
GenerateJavaExtended javaGenerator = new GenerateJavaExtended(URI.createFileURI("../Model.xmi"),
new File("../myOutputFolder"), new ArrayList<Object>());
javaGenerator.doGenerate(null);
I added the org.eclipse.gmt.modisco.java.generation as a dependencie to my plugin.xml but it doesn't work.
So can someone help me?
Greetings
Marcus
[Updated on: Mon, 09 January 2012 11:26] Report message to a moderator
| Re: Generate Java code from a Java model [message #804477 is a reply to message #790618] |
Wed, 22 February 2012 12:13   |
Fabien Giquel Messages: 134 Registered: July 2009 |
Hi David,
glad that you have succeeded in launching generation from some main() method, calling some xmi resource factory registration.
There are several ways of reusing the generation acceleo module, with several technical difficulties. We recommend this one : invoking GenerateJavaExtended class in one java plugin project, with dependencies to org.eclipse.gmt.modisco.java.generation installed plugin. Then the code must be executed within an eclipse context ("Eclipse Application" Run Config)
Modisco Documentation has been updated (Bug 372090) for focusing on this recommendation.
Fabien.
Fabien GIQUEL
R&D Engineer
Mia-Software
4, rue du Château de l'Eraudiere
44324 NANTES CEDEX 03
| Re: Generate Java code from a Java model [message #945709 is a reply to message #939078] |
Mon, 15 October 2012 11:01   |
Hi Benjamin,
thank you for these observations.
2a) i have updated the wiki documentation
2b) i was not aware of these google plugins dependency. I will have a look at it for understanding.
Fabien
Fabien GIQUEL
R&D Engineer
Mia-Software
| Re: Generate Java code from a Java model [message #994081 is a reply to message #776997] |
Wed, 26 December 2012 05:31  |
From what i understand, com.google.guava dependency should have been transparantly fixed with Bug 364265.
Fabien GIQUEL
R&D Engineer
Mia-Software
FUDForum. Page generated in 0.04912 seconds
