Home » Modeling » EMF » How to avoid an EMF Object in XMI serialisation
How to avoid an EMF Object in XMI serialisation [message #993377] Mon, 24 December 2012 02:38 Go to next message
Raghava Rao is currently offline Raghava Rao
Member
I want to avoid an EMF object in XMI serialisation. I can not change the ecore model.
Suppose 'A' is the class in the model.I created a class 'B' by extending 'A'.I should be able to serialise the class 'A' objects.
I should not serialise the class 'B' object during XMI serialisation.
please suggest is there any way to achieve this?
Advance thanks for your reply.
Raghav
Re: How to avoid an EMF Object in XMI serialisation [message #993413 is a reply to message #993377] Mon, 24 December 2012 05:00 Go to previous message
Ed Merks is currently offline Ed Merks
Raghav,
If you don't want certain features serialized, you should make set them
to be transient. You can look at how
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.Lookup.featureKind(EStructuralFeature)
relies on that. In that method, it doesn't know which class was being
considered, so likely you'd need to specialize
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.Lookup.getFeatures(EClass)
itself to return results to indicate that the feature should be treated
as transient. You can use OPTION_USE_CACHED_LOOKUP_TABLE to specify
your own specialized Lookup class
@SuppressWarnings("unchecked") List<Object> lookup =
(List<Object>)options.get(XMLResource.OPTION_USE_CACHED_LOOKUP_TABLE);
if (lookup != null)
// caching turned on by the user
if (lookup.isEmpty())
featureTable = new Lookup(map, extendedMetaData, elementHandler);
lookup.add(featureTable);
else
featureTable = (Lookup)lookup.get(INDEX_LOOKUP);
else
//no caching
On 24/12/2012 8:38 AM, Raghava Rao wrote:
> Hello,
> the ecore model.
> Raghav
Previous Topic:eInvoke fails
Next Topic:Xcore vs EntityDSL
Current Time: Thu May 23 15:40:27 EDT 2013
Powered by FUDForum. Page generated in 0.01531 seconds
