| Maven Xtend compiler - file encoding [message #764207] |
Sun, 11 December 2011 12:03  |
Matthijs Messages: 11 Registered: August 2011 |
Junior Member |
There is probably an issue with file encoding in the maven-xtend-compiler.
Because xtext uses guillemot brackets («»), all my xtend files are in ISO-8859-1 encoding. Running the maven-xtend-compiler on Windows works fine, but on the Linux build the guillemot characters are not recognized. I think the xtend-compiler on Linux should be forced to read the files in ISO-8859-1 encoding.
This can be solved by calling the compiler (org.eclipse.xtext.xtend2.compiler.batch.Main) with a jvm parameter for the encoding, e.g. -Dfile.encoding=ISO-8859-1.
Matthijs
| Re: Maven Xtend compiler - file encoding [message #764234 is a reply to message #764207] |
Sun, 11 December 2011 13:11   |
Sven Efftinge Messages: 1667 Registered: July 2009 |
Please file a bugzilla. I don't think we want to enforce an encoding
(And if it would be UTF-8). But it should be simple to configure the
encoding just for the Xtend compiler.
Am 12/11/11 6:03 PM, schrieb Matthijs:
> Regards
> Matthijs
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Need professional support for Xtext and EMF?
Blog : blog.efftinge.de
| Re: Maven Xtend compiler - file encoding [message #992431 is a reply to message #764207] |
Fri, 21 December 2012 11:07  |
Solomon Obi Messages: 1 Registered: December 2012 |
Junior Member |
I am running the batch compiler through maven using the tend-maven-plugin. Below an excerpt from my pom
What do I use in configuration to ensure the right file encoding
<plugin>
<groupId>org.eclipse.xtend</groupId>
<artifactId>xtend-maven-plugin</artifactId>
<version>2.3.1</version>
<executions>
<execution>
<phase>generate-sources</phase>
<goals>
<goal>compile</goal>
<goal>testCompile</goal>
</goals>
</execution>
</executions>
<configuration>
<outputDirectory>${basedir}/xtend-gen</outputDirectory>
</configuration>
FUDForum. Page generated in 0.01780 seconds
