Home » Eclipse Projects » Buckminster » swt error - has anybody seen that?
swt error - has anybody seen that? [message #992421] Fri, 21 December 2012 10:45 Go to next message
Axel Guckelsberger is currently offline Axel Guckelsberger
Hi all,
I am getting a weird error for a good while (probably since the update to Juno) in all my Jenkins builds.
ERROR: [SCR] Error while attempting to deactivate instance of component Component[
	name = org.eclipse.e4.ui.css.swt.theme
	activate = activate
	deactivate = deactivate
	modified =
	configuration-policy = optional
	factory = null
	autoenable = true
	immediate = true
	implementation = org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager
	state = Disabled
	properties =
	serviceFactory = false
	serviceInterface = [org.eclipse.e4.ui.css.swt.theme.IThemeManager]
	references = null
	located in bundle = org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624 [591]
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
	at java.lang.Class.getDeclaredMethods(Class.java:1791)
	at org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
	at org.eclipse.equinox.internal.ds.model.ServiceComponent.deactivate(ServiceComponent.java:337)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.deactivate(ServiceComponentProp.java:161)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:389)
	at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:102)
	at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:366)
	at org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:306)
	at org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:717)
	at org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:693)
	at org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
	at org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
	at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
	at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
	at org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
	at org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
	at org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
	at org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
	at org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.ClassNotFoundException: org.eclipse.swt.widgets.Display
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	... 39 more
This seems to be independent of which bundles are installed in the headless Buckminster environment (using five different ones which contain different bundles).
Also this error occurs in all job types, may it building a p2 repository for a certain component / feature, or may it running a test suite.
Has maybe anybody seen this before?
Thank you, Axel
Re: swt error - has anybody seen that? [message #992685 is a reply to message #992421] Sat, 22 December 2012 04:38 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
as far as I know buckminster headless should not use swt stuff... what
features have you installed in your headless buckminster?
cheers
Lorenzo
On 12/21/2012 04:45 PM, Axel Guckelsberger wrote:
> Hi all,
> Component[
> activate = activate
> modified = configuration-policy = optional
> factory = null
> autoenable = true
> immediate = true
> implementation =
> state = Disabled
> properties = serviceFactory = false
> references = null
> located in bundle =
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> ... 39 more
> Thank you, Axel
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: swt error - has anybody seen that? [message #992692 is a reply to message #992685] Sat, 22 December 2012 05:01 Go to previous messageGo to next message
There are the default features:
- http://download.eclipse.org/tools/buckminster/headless-4.2
org.eclipse.buckminster.pde.headless.feature
org.eclipse.buckminster.git.headless.feature
org.eclipse.buckminster.emma.headless.feature
- http://download.cloudsmith.com/buckminster/external-4.2
And these additional ones:
- emf codegen ecore including the ant capability
http://download.eclipse.org/releases/juno/ org.eclipse.emf.codegen.ecore
- emf converter
http://download.eclipse.org/releases/juno/ org.eclipse.emf.converter
- mwe
http://download.eclipse.org/releases/juno/ org.eclipse.emf.mwe.core
Going to try out whether the error occurs also without the three additional
features, too.
Axel
> cheers
> Lorenzo
>> Hi all,
>> Component[
>> activate = activate
>> factory = null
>> autoenable = true
>> immediate = true
>> implementation =
>> state = Disabled
>> references = null
>> located in bundle =
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 39 more
>> Thank you, Axel
Re: swt error - has anybody seen that? [message #992707 is a reply to message #992692] Sat, 22 December 2012 05:57 Go to previous messageGo to next message
Hi Lorenzo,
seems like the org.eclipse.emf.mwe.core feature indeed introduced the SWT
dependencies. Thanks again, now I can investigate further!
Axel
Re: swt error - has anybody seen that? [message #992761 is a reply to message #992707] Sat, 22 December 2012 09:39 Go to previous messageGo to next message
On 12/22/2012 11:57 AM, Axel Guckelsberger wrote:
> Hi Lorenzo,
> Axel
but do your Jenkins job fail because of those exceptions? Otherwise you
might ignore them (not sure though :)
cheers
Lorenzo
Re: swt error - has anybody seen that? [message #993052 is a reply to message #992421] Sun, 23 December 2012 02:57 Go to previous message
Eike Stepper is currently offline Eike Stepper
Am 21.12.2012 16:45, schrieb Axel Guckelsberger:
> Hi all,
That one is annoying. I had to go back to org.eclipse.buckminster.site.eclipse.headless_1.5.0.v20121007-1625.zip ;-(
Cheers
/Eike
http://www.esc-net.de
Previous Topic:creating an action which depends on other components' actions
Next Topic:qualifier.replacement does not work in the IDE?
Current Time: Thu May 23 15:35:11 EDT 2013
Powered by FUDForum. Page generated in 0.01866 seconds
