Home » Eclipse Projects » NatTable » how to use ListDataProvider class...(package org.eclipse.nebula.widgets.nattable.data)
icon5.gif  how to use ListDataProvider class... [message #991710] Wed, 19 December 2012 21:54 Go to next message
lau alex is currently offline lau alex
hello:
i want to use MouseListener (mouseDoubleClick) get the current object.
object o = ListDataProvider.getRowObject(int rowIndex);
how to write in the mouselistener, or other implementation method。
please help.... Embarrassed Embarrassed Embarrassed Embarrassed Embarrassed Embarrassed
example :
package com.eoilio.mrpii.ui.currency;
 * Copyright (c) 2012 Original authors and others.
 * All rights reserved. This program and the accompanying materials
 * are made available under the terms of the Eclipse Public License v1.0
 * which accompanies this distribution, and is available at
 * http://www.eclipse.org/legal/epl-v10.html
 * Contributors:
 *     Original authors and others - initial API and implementation
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.config.CellConfigAttributes;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.data.ListDataProvider;
import org.eclipse.nebula.widgets.nattable.layer.cell.CellOverrideLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.style.CellStyleAttributes;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.nebula.widgets.nattable.style.Style;
import org.eclipse.nebula.widgets.nattable.util.GUIHelper;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseListener;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.springframework.context.ApplicationContext;
import ca.odell.glazedlists.GlazedLists;
import com.eoilio.mrpii.dao.AppContext;
import com.eoilio.mrpii.dao.Currencycodedata;
import com.eoilio.mrpii.dao.CurrencycodedataDAO;
import com.eoilio.mrpii.ui.widget.nattable.AbstractNatExample;
import com.eoilio.mrpii.ui.widget.nattable.extension.builder.NatTableBuilder;
import com.eoilio.mrpii.ui.widget.nattable.extension.builder.model.TableColumn;
import com.eoilio.mrpii.ui.widget.nattable.extension.builder.model.TableModel;
public class CurrencyBuilder extends AbstractNatExample implements MouseListener {
	private NatTableBuilder<Currencycodedata> builder;
	private NatTable natTable;
	public Control createExampleControl(Composite parent) {
		ApplicationContext appCon = AppContext.CreateApplicationContext();
		CurrencycodedataDAO dao = (CurrencycodedataDAO) appCon
				.getBean("CurrencycodedataDAO");
		TableColumn[] columns = new TableColumn[] {
				new TableColumn(0, "code", "编码").setWidth(60).setCategory("A"),
				new TableColumn(1, "name", "币别").setWidth(60).setCategory("A"),
				new TableColumn(2, "exchange", "汇率").setWidth(80).setCategory(
						"A"),
				new TableColumn(3, "commutedDes", "折算方式").setWidth(200)
						.setCategory("A") };
		TableModel table = new TableModel(columns);
		builder = new NatTableBuilder<Currencycodedata>(parent, table,
				GlazedLists.eventList(dao.findAll()),
				Currencycodedata.rowIdAccessor);
		// Setup all the layer stacks
		natTable = builder.setupLayerStacks();
		natTable.addMouseListener(this);
		// Since the build() method has not been invoked yet you can
		// tweak layer configuration as you want
		customize();
		return builder.build();
	private void customize() {
		Style style = new Style();
		style.setAttributeValue(CellStyleAttributes.BACKGROUND_COLOR,
				GUIHelper.COLOR_RED);
		ListDataProvider<Currencycodedata> bodyDataProvider = builder
				.getBodyLayerStack().getDataProvider();
		CellOverrideLabelAccumulator<Currencycodedata> myAccumulator = new CellOverrideLabelAccumulator<Currencycodedata>(
				bodyDataProvider);
		myAccumulator.registerOverride("AAA", 2, "myLabel");
		builder.addCellLabelsToBody(myAccumulator);
		IConfigRegistry configRegistry = natTable.getConfigRegistry();
		configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_STYLE,
				style, DisplayMode.NORMAL, "myLabel");
	public void mouseDoubleClick(MouseEvent event) {
		// TODO Auto-generated method stub
		System.out.println(event.toString());
	public void mouseDown(MouseEvent event) {
	public void mouseUp(MouseEvent event) {
Re: how to use ListDataProvider class... [message #991956 is a reply to message #991710] Thu, 20 December 2012 09:49 Go to previous message
Dirk Fauth is currently online Dirk Fauth
there are several ways to achieve this.
1. Use tight coupling, which might be working for your example.
public void mouseDoubleClick(MouseEvent e) {
	//get the row position for the click in the NatTable
	int rowPos = natTable.getRowPositionByY(e.y);
	//transform the NatTable row position to the row position of the body layer stack
	int bodyRowPos = LayerUtil.convertRowPosition(natTable, rowPos, gridLayer.getBodyLayer());
	Currencycodedata ccd = bodyDataProvider.getRowObject(bodyRowPos);
	//Do something with ccd
2. You might want to use the selection provider mechanism
// Provides rows where any cell in the row is selected
ISelectionProvider selectionProvider = new RowSelectionProvider<Person>(gridLayer.getBodyLayer().getSelectionLayer(), bodyDataProvider, false);
selectionProvider.addSelectionChangedListener(new ISelectionChangedListener() {
	public void selectionChanged(SelectionChangedEvent event) {
		System.out.println("Selection changed:");
		IStructuredSelection selection = (IStructuredSelection) event.getSelection();
		@SuppressWarnings("rawtypes")
		Iterator it = selection.iterator();
		while (it.hasNext()) {
			System.out.println("  " + it.next());
The second code example is out of the Get_and_set_selected_objects examples of the NatTable examples.
Hope that helps,
Dirk
Previous Topic:Making columns sortable
Next Topic:about ListDataProvider.getRowObject(int rowIndex) Method of use
Current Time: Tue May 21 07:48:05 EDT 2013
Powered by FUDForum. Page generated in 0.02621 seconds
