| Question about "Couldn't resolve reference to JvmIdentifiableElement" [message #991480] |
Wed, 19 December 2012 07:39  |
Andreas Brieg Messages: 48 Registered: November 2012 |
Member |
I wanted to create a visualization of a part of the MoDisco Java Model with the help of the Generic Graph View.
So I started to write the mapping and got that far:
import org.eclipse.gmt.modisco.java.*
diagram JavaDiagram type Model {
node DeclarationNode for this.compilationUnits {
The problem is that compilationUnits is marked with the compilation error :Quote:Couldn't resolve reference to JvmIdentifiableElement 'compilationUnits'.
From the answers to this topic I know I should reference the xbase.lib in the project that contains the model. However the MoDisco Java Model is contained in the plugin org.eclipse.gmt.modisco.java, which I don't have control over.
Is there another way to solve that problem? Including the plugin org.eclipse.xtext.xbase.lib as a dependency in the project where I'm visualizing the model doesn't help.
Thanks for advice.
FUDForum. Page generated in 0.05238 seconds
