| SSCCE Project Setup... [message #991513] |
Wed, 19 December 2012 11:03 |
Jim Crowell Messages: 17 Registered: July 2009 |
Junior Member |
I need to build a SSCCE file to send to a Java Forum...
The Java class in question is currently > 2000 lines of code.
To isolate the problem, I need to copy the Java class file to a work area and
systematically remove code that does not apply to the problem.
My options are:
1) Use a text editor [e.g. BBEdit] and to compile and execute the
code using the MAC OS C terminal.
2) Setup a new Eclipse Project baselined with the class in question.
In either case I'll need to add code with a 'main' method so that the resultant
SSCCE file can be run from the terminal.
Question:
Is there any available documentation that I can review before trying to implement
option 2)?
FYI:
I am using Eclipse Galileo [Build id: 20100218-1602] on an iMac computer
with Mac OS X 10.6.8 [Snow Leopard]...
Eclipse is using the JVM 1.6.x Mac OS X default compiler...
FUDForum. Page generated in 0.08255 seconds
