Home » Eclipse Projects » NatTable » Making columns sortable
Making columns sortable [message #991360] Tue, 18 December 2012 12:30 Go to next message
Alex Kipling is currently offline Alex Kipling
Hello, I tried to adopt the sortable columns example, but failed.
What am i missing?
import java.util.Comparator;
import org.eclipse.nebula.widgets.nattable.NatTable;
import org.eclipse.nebula.widgets.nattable.config.AbstractRegistryConfiguration;
import org.eclipse.nebula.widgets.nattable.config.DefaultNatTableStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.config.IConfigRegistry;
import org.eclipse.nebula.widgets.nattable.config.IConfiguration;
import org.eclipse.nebula.widgets.nattable.config.NullComparator;
import org.eclipse.nebula.widgets.nattable.data.IDataProvider;
import org.eclipse.nebula.widgets.nattable.examples.AbstractNatExample;
import org.eclipse.nebula.widgets.nattable.examples.runner.StandaloneNatExampleRunner;
import org.eclipse.nebula.widgets.nattable.grid.GridRegion;
import org.eclipse.nebula.widgets.nattable.grid.data.DummyBodyDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.data.DummyColumnHeaderDataProvider;
import org.eclipse.nebula.widgets.nattable.grid.layer.ColumnHeaderLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayer;
import org.eclipse.nebula.widgets.nattable.layer.AbstractLayerTransform;
import org.eclipse.nebula.widgets.nattable.layer.CompositeLayer;
import org.eclipse.nebula.widgets.nattable.layer.DataLayer;
import org.eclipse.nebula.widgets.nattable.layer.ILayer;
import org.eclipse.nebula.widgets.nattable.layer.cell.ColumnOverrideLabelAccumulator;
import org.eclipse.nebula.widgets.nattable.selection.SelectionLayer;
import org.eclipse.nebula.widgets.nattable.selection.config.DefaultSelectionStyleConfiguration;
import org.eclipse.nebula.widgets.nattable.sort.SortConfigAttributes;
import org.eclipse.nebula.widgets.nattable.sort.config.SingleClickSortConfiguration;
import org.eclipse.nebula.widgets.nattable.style.DisplayMode;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
public class ColumnHeaderSelectionDataLayerExample extends AbstractNatExample {
	private static final String CUSTOM_COMPARATOR_LABEL = "customComparatorLabel";
	protected static final String NO_SORT_LABEL = "noSortLabel";
	public static void main(String[] args) throws Exception {
		StandaloneNatExampleRunner.run(new ColumnHeaderSelectionDataLayerExample());
	public Control createExampleControl(Composite parent) {
		DummyBodyDataProvider bodyDataProvider = new DummyBodyDataProvider(1000000, 1000000);
		SelectionLayer selectionLayer = new SelectionLayer(new DataLayer(bodyDataProvider));
		DataLayer colDataLayer = new DataLayer(new DummyColumnHeaderDataProvider(bodyDataProvider));
		ILayer columnHeaderLayer = new ColumnHeaderLayer(colDataLayer, selectionLayer, selectionLayer);
		CompositeLayer compositeLayer = new CompositeLayer(1, 2);
		compositeLayer.setChildLayer(GridRegion.COLUMN_HEADER, columnHeaderLayer, 0, 0);
		compositeLayer.setChildLayer(GridRegion.BODY, selectionLayer, 0, 1);
		NatTable nattable =  new NatTable(parent, compositeLayer, false);
		nattable.addConfiguration(new DefaultNatTableStyleConfiguration());
		// Change the default sort key bindings. Note that 'auto configure' was turned off
		nattable.addConfiguration(new SingleClickSortConfiguration());
		nattable.addConfiguration(getCustomComparatorConfiguration( colDataLayer ));
		nattable.addConfiguration(new DefaultSelectionStyleConfiguration());
		nattable.configure();
		return nattable;
	 * NOTE: The labels for the the custom comparators must go on the columnHeaderDataLayer - since,
	 * 		the SortHeaderLayer will resolve cell labels with respect to its underlying layer i.e columnHeaderDataLayer
	private IConfiguration getCustomComparatorConfiguration(final AbstractLayer columnHeaderDataLayer) {
		return new AbstractRegistryConfiguration() {
			public void configureRegistry(IConfigRegistry configRegistry) {
				// Add label accumulator
				ColumnOverrideLabelAccumulator labelAccumulator = new ColumnOverrideLabelAccumulator(columnHeaderDataLayer);
				columnHeaderDataLayer.setConfigLabelAccumulator(labelAccumulator);
				// Register labels
				labelAccumulator.registerColumnOverrides(
	              1, CUSTOM_COMPARATOR_LABEL);
                     2,
                     NO_SORT_LABEL);
				// Register custom comparator
				configRegistry.registerConfigAttribute(SortConfigAttributes.SORT_COMPARATOR,
									                       getCustomComparator(),
									                       DisplayMode.NORMAL,
				// Register null comparator to disable sort
				                                       new NullComparator(),
				                                       DisplayMode.NORMAL,
				                                       NO_SORT_LABEL);
	private Comparator getCustomComparator() {
		return new Comparator() {
			public int compare(Object o1, Object o2) {
				return ((String) o1).compareToIgnoreCase((String) o2);
Re: Making columns sortable [message #991443 is a reply to message #991360] Wed, 19 December 2012 03:07 Go to previous message
Dirk Fauth is currently offline Dirk Fauth
what you are missing is the sorting. It looks like you copied some code out of the SortableGridExample which uses a custom GlazedLists grid with special layers there. The sort configuration you copied will be used by the GlazedListsSortModel, which you don't use in your example.
Furthermore, in your example you don't configure a SortHeaderLayer. If you want to use sorting with such a simple example (that means without GlazedLists), just add the SortHeaderLayer on top of your ColumnHeaderLayer and define your custom ISortModel. The getCustomComparatorConfiguration() is not needed there.
You can find some additional NatTable examples here http://www.beone-group.com/publikationen.html in the "NatTable 2.2 - ..." section. There is an example for sorting there, so maybe this helps you in understanding what to do.
Greez,
Dirk
P.S. This is also described here http://eclipse.org/nattable/documentation.php?page=sorting
Previous Topic:Column width and column resizing
Next Topic:how to use ListDataProvider class...
Current Time: Sun May 19 00:22:05 EDT 2013
Powered by FUDForum. Page generated in 0.01775 seconds
