| [Data Binding] Binding depends on another binding [message #987609] |
Tue, 27 November 2012 05:27  |
Ted Mosby Messages: 8 Registered: April 2012 |
Junior Member |
I have a question. Is it possible that a binding depends on another binding? I have a combobox which contains profile names. If i choose a profile name some other widgets will be filled with the values of the chosen profile. I wanted to know if it is possible to fill the other widgets when a profile is selected in the combobox with data binding? I bound the combobox to a model property, when the user select another profile, the value will be changed and the other widgets should be updated. Can i do this only with data binding? Or must i call the setter for all widgets manually?
Thx!
FUDForum. Page generated in 0.05442 seconds
